1,821 - 1,840 of 1,862 Posts
Resurrection again.. I have tried to search there are just too many posts.
What is the proper way to install a crankcase catch can? Is it to be filtered prior or post PCV valve?
It seems that most catch cans are utilizing a bronze filter of some type. This works well, however, there is another name for this device: porous plug, or "throttling valve." There is going to be a reduction of pressure through the catch can no matter what- unless it was designed specifically around this criteria (which I have yet to see, even in mishimotos LARPY catch can advertisement). This will have a reduced pressure post-can and an increased pressure prior to the can. I am concerned that the drop in pressure, before or after the valve will be an issue and cause it to function differently. Maybe it isn't a problem and I'm overthinking. I am a new STI/turbo car owner, but otherwise an experienced "car guy." I don't want to get this wrong and end up in trouble.
It depends on the system, but on an EJ powered STi the can or AOS is before the PCV Valve. With an FA it's after. That is, if your AOS or catch can retains the PCV Valve (ours doesn't). Be aware that any AOS or catch can that uses media WILL clog over time if you're not on top of the maintenance, and media units tend to increase crankcase pressure as well. If you haven't noticed, my personal preference is to have the freest flowing unit, that works well too ;)
So has anyone put a gauge on the crankcase? I don't want to sorry about a 1 psi increase- no need to "re-engineer the wheel" over that. I will have to look into the PCV delete concept. As I said, I'm new and a little green yet. Feel free to link any literature you think is necessary/good to know.
Yes. We tested 3 cars for over a year under pretty much every condition you can think of in a Subaru. We did this before even considering release to the public.
Under low load you'll see 1-2psi of crankcase pressure depending on many factors. An increase of 1psi may not sound like much, but is potentially a 50-100% increase in pressure. Under load you will (should) pull a slight vacuum depending on what type of system you have in place. VTA setups will build pressure. Again, the more vacuum you have, the happier your engine will be with better ring seal, lower oil consumption, and higher potential to make power.
Quality info. Much appreciated. I'm not a huge fan of the VTA/check valve setup, either. People seem to forget that a few PSI in a large surface area can amount a significant amount of force... would stink to have to pull the motor to do gaskets (or worse) for being too cheap to properly handle your air separation lol. Cheers.
... on an EJ powered STi the can or AOS is before the PCV Valve.
Chris, you wrote that where it could be interpreted as a catch "can" or air oil separator could be called either or, and essentially be the same. I know you know a catch can is not an A/OS and vice-versa. I just want to be clear that an A/OS doesn't hold oil, it separates it out and normally returns oil to the engine crankcase.
If a catch can is used in conjunction with an A/OS it should be connected to catch the remnants of the oil or fuel vapors off the top of the A/OS (and it is normally run as VTA). Some do catch what drains from the A/OS and throw it away, as being contaminated. This also has its risks of overflowing through the vent or going back into the intake tract, if it's a closed system.
I think Owen H must consider his states laws and whether he configures a system that is legal (and easily inspectable) or not or wants to skirt the laws. Then there is the warranty disqualification issues of a modified system.
Perhaps you could elaborate as to how you think best to deal with a VTA A/OS? For instance, plumbing it into the exhaust, post turbo/post Cat, is one option besides a can.
It was written to mean if you have on or the other as they are plumbed the same from the venting lines standpoint.
A can's outlet can be VTA or plumbed to a vacuum source, just like any AOS. VTA is not my preference as it causes pressure in the crankcase instead of a vacuum.
boy I remember when this thread was started.
FYI - I have killerb's new catch can and I have used just about every single one before and have seen installs of a lot.
I have not installed killerb's yet, but I can say that craftsmenship is beautiful and the entire setup is simple. I don't want coolant lines (my car avoid's cold weather anyway), and it simplifies the hose routing.
i've installed IAG/cobb before and holy smokes. looks like the movie independence day with the tentacles all over.
I will post back when I do install the entire system over the winter, I am pulling my motor to refresh it.
Can I possibly get confirmation on the size of the OE vent lines? I.D. is the dimention I am interested in. Whatever information is helpful. It appears that any attempt to dissect the OE system is going to be a destructive process.
1/2" for the head ports and 3/4" for the crankcase.
So all of the head lines and related are 1/2 throughout?
The crankcase is 3/4" throughout including the PCV system?
It's gnarly cold outside and i dont have an inside space to work really. Sorry for begging to be spoon fed lol. I am wanting to order some hose and do it all at once without going to and from Advance 4 times. It also seems that once I begin, I either must finish the install or park the car. I anticipate the hard plastic lines being compromised in the process.
I appreciate your consistent public service on here too. Thank you!
Correct, the head lines are all 1/2". The port on the crankcase is 3/4, but I don't know what you're doing from that point out. OEM (year dependent) has a plastic wye adapter right at the top of that port that reduces, but most aftermarket AOS/Catch Cans use a 3/4" hose on that connection. Without knowing the MY and what you're trying to accomplish, it's tough to give a confident path for success.
I remember last time we talked you appeared to know a thing or ten about this. In your opinion, would I be hurting the car by using a reducer and bringing it ALL down to 1/2 throughout? It would really make life easy. I am looking to keep all of the PCV stuff as OEM as possible. It hurts the value of the discussion that I have not yet pulled the intercooler off to get a specific look. I'm kind of vague I'm sure. Per our last chat, you instructed me that the separation should take place prior to the valve. I am just not sure about any of the flow characteristics of this stuff so I can't make a confident or knowledgeable decision about it.
Edit: Car is a 2016 if it matters.
If you're at stock to stage 2-ish power levels necking the crankcase down to 1/2" is fine. The factory part itself necks down, so you won't be any worse off :)
MAP stage 2 kit is all this car will ever get, at least for the foreseeable future. If I upgrade it more.. it'll probably cease to be a DD after that. Thanks a ton for the help man.
ya, you can get a TEE that's 3/4" at the bottom and 1/2" on each side, this is how I use to mock up the lines..depends on your turbo setup though too, i was doing this with rotated setups. factory location is a bit tighter, so you just have to play around. but you're safe with 3/4" hose and 1/2" hose to do everything and get good quality hose.
Okay so how's this looking?
61414
@muller_777 @killerbmotorsport
No matter what I am going to be using the 1/2 can inlet. I just don't want to worry too much about the increase in crank pressure over the major and minor reductions in the hose and the can. We'll stop beating the dead horse after this i promise hahaha. This has been a neat little project I'll say.
Is the hose 3/4" at the intake as well? As in, there's a 3/4 bung on the inlet somewhere? I don't want to take it all apart and then have to get a ride to work or next day ship stuff because I don't have the right parts lol.
Thanks for the help guys. You have my gratitude for sure.
