1 - 20 of 1821 Posts
Ok... So I searched and searched, and researched and researched, and after many sleepless nights and reading endless threads regarding the topic at hand, I’ve decided to try and start a thread that would help everyone, including myself, who was interested in researching such topics, make the right decisions.
So I’ll start out by adding what I've learned in my studies and what I'm still a little confused about. If anyone more knowledgeable has anything helpful to add please do so and I’ll keep track of all the information and Ill summarize it here in the first post so it will be easy to find for anyone who is just passing through to get information.
What happens in the STi engine crankcase while driving?
In regards to the Subaru STi engine, as I understand it (and I may be wrong, but I would like to share my thoughts and hopefully confirm them), the stout 2.5 liter boxer motor generates quite a bit of pressure in the crankcase during high revs. This pressure can put a drag on the engine if not ventilated efficiently. It can also force oil pass the piston rings, into the cylinders, burning off in the combustion chamber and causing lean conditions, which can be bad for our motors and all turbo charged motors as a whole. Under boost the high pressure of the Forced Induction can also get by the piston rings in the opposite direction entering the Crankcase and adding to the high pressure all ready in there from revving. This also can introduce contaminants into the oil as well as un-burned fuel vapor.
What is Crankcase Ventilation and why is it necessary?
All of these ill effects can be avoided by sufficient venting of the engine by utilizing the constant vacuum in the inlet tube of the intake track, to pull all the added pressure out of the crankcase with a series of venting tubes, and check valves. Most stock motors have a sufficient venting system that is designed for their specific performance levels, (i.e. the positive crankcase ventilation system, aka PCV). There is an upside and a downside to this mechanism. The upside to this is... It relieves the pressure in the crankcase, as well as re-circulates the un-burned fuel vapor into the intake track and insures proper burning of the fuel. This helps keep harmful fumes from polluting our environment and helps improve gas mileage. The downside is... Along with pressure and fuel vapor coming out of the motor through the venting tubes, Oil Vapor also makes its way into the intake track (aka Blow By). ESPECIALLY under high revs and high boost. This is why most modded STi’s experience excessive blow by. Oil vapor can be harmful to the Turbo and make a mess of things in the entire Intake system and intercooler, as well as causing lean conditions by being burned in the engine. It can also cause an excess of carbon build up in the engine (from burning the oil). These problems usually don’t occur in a stock STi because the boost and performance levels are not high enough to cause any blow by.
How can you avoid “Blow By”?
The way to avoid "Blow By" is with proper venting and by using a device that will take the Oil vapor out of suspension and maintain the flow of un-burned air/fuel vapor out of the crankcase and into the Intake. An “Oil Catch Can” accomplishes this by passing the flow through a baffled can that has inlet and outlet ports for the venting tubes and helps keep the oil in the can and out of the intake. An Air/Oil separator accomplishes this the same way; however it has an additional port on the bottom of the canister to allow oil to drain back into the engine.
Now... After covering the necessity of venting the engine, what blow by is, the conditions that cause blow by and the way to help avoid blow by, the only other thing that needs to be covered is what I am still a little confused about... The Plumbing!
Plumbing
The way the STi Engine’s stock venting system is plumbed, is obviously done for a reason. Who are we to argue with years of engineering that the Subaru developers have put into designing the engine? However, as I said before the Stock engine doesn’t really see much blow by due to its lack of High Performance and Boost. The STi engine is obviously a high performance motor; however the stock venting system is designed to be sufficient for its performance level. So when boost and performance is taken up a notch and the need for a Catch Can or an A/O separator is required to eliminate blow by, how should it be plumbed? Can simply intercepting the inlet tubes with a catch can or an a/o separator be enough to get the job done? If so then why do aftermarket companies have installation guides that indicate certain changes to the plumbing of the venting system when installing their separators, and why do others simply instruct a simple interception in the lines? What are the benefits and draw backs of each and are they performance level dependent or a result of research and development, to prove one method better than another?
So which way is the best and what’s the reasoning behind why each company suggests a certain way to install their venting tubes?
After I discovered the importance of an air/oil separator I began my research and after all was said and done, I have a pretty decent understanding of everything except the plumbing. I have yet to understand why each method is done and what the best way to plumb the venting tubes is for each specific application. This is what drove me to start this thread. I didn’t want to just post a simple thread with a question. I wanted to provide a source of information for everyone else who is haunted by these questions and just the idea of A/O separators and Catch Cans in general.
I recently purchased and installed an Air/Oil separator made by Ixiz Concepts. I'm sure many of you have heard of a few different ones on the market. I was on the fence between Crawford’s and this one because of some reviews I’ve read and the overall quality they seemed to have. In the end it really came down to cost. I found one that was brand new for significantly lower than retail. So I picked it up and installed it. I really felt that I needed one since I just added a few more power mods that put my power numbers significantly higher than stock, and I wanted peace of mind and to be able to run said power safely for as long as I can. When it came time to installing it I decided to use the Crawford Installation guide to plumb my tubes, despite the fact that Ixiz’s installation guide is actually different from Crawford’s, I felt that Crawford’s seemed a little more logical to me after my studies of the STi’s ventilation system. I've made a few diagrams of the plumbing in detail to show you the difference and hopefully get some help to figure out which way is the best and why. I used a diagram that I got off NASIOC as a starting point and added to them for further clarification.
Figure 1: The Stock STi Engine PCV plumbing.
Figure 2: The Stock system under Vacuum.
Figure 3: The Stock system under Boost.
Figure 4: Crawford’s recommended installation method.
Figure 5: Ixiz’s recommended installation method.
Figure 6: LiteSpeed's Blowby Solution Twin Catch Can System
Discussion.
Why does Crawford recommend completely removing the PCV and capping the port on the Intake manifold/TB, completely separating it from the venting system? Is this bad? Is this good? And why? I hope someone can shed some light on this specific question and add or correct any information already in here.
Thank you for reading and I hope this becomes a very helpful and informative thread for all to share. Please Discuss…
Jay
Yeah that is why I have dual catch cans. I don't think the breathers are very important though, that is why the Crawford A/O separator does not have connections to the head breathers.
The purpose of crankcase ventilation is to remove water and gas from the oil. When cruising, this is removed "mostly" from the crankcase, not the head breathers. I have clear lines on my catch cans and the head breathers hardly suck in anything. The crankcase breather sucks in a good bit of crap. Yes I have a PCV valve still.
I've opened up my Ixiz A/O Separator in the past so I've studied the baffling and understand how it attempts to separate the oil. I've posted pictures before but was asked nicely by the seller to remove them. I'll share them via PM
Does anyone have pictures or diagrams of the internals of a catch can? I would like to understand how the generic catch can works. Thanks
The PVC valve sucks oil out of the crankcase during non boosted situations. This allows oil into the intake manifold which consumes oil from the crankcase and eventually causes detonation. Another issue with the PVC valve is it will fail in time causing your crankcase to become pressurized during boosted situations.
We choose the safest method available to keep our motors alive while making big HP.
As a side note, we do vent the valve covers into the side of our AOS which causes a swirl pot effect separating the air from the oil.
Any other questions?
Team Crawford
I love my Crawford air/oil separator. But we noticed some oil spray/residue in my turbo inlet coming out of the a/o sep. And my tuner told me to disconnect the air/oil separator from the turbo inlet and run it into a soda bottle or something when I am at the dragstrip :confused:
Your tunner is right. When you're pushing to the max it's safer to vent the AOS into a container.
We do this on our TA car for the final races when the motor is set on Kill!
Team Crawford
Discussion.
Jay
Thanks for making this thread, great idea! I'm trying to figure this all out as well. The idea of the pcv valve (im port) is to suck all the unwanted crap out of the crankcase under low load from my understanding (thanks gabedude!), while the other port on the valve - one that goes to inlet - opens under boost. My only concern with ditching the pcv valve (im port) is that there won't be enough vacuum on the turbo inlet to pull all of the crap out of the crankcase under low load.
It's interesting that the ixiz separator keeps the pcv.
Gabe, didn't you seal off the port on your pcv valve that goes to the turbo inlet (i.e. you're only running the port that goes to the im)? If this is the case does the pcv/im port stay open during boost? How often do you have to drain the catch can that's tied into the pcv?
Discussion Starter #10
Why is the PCV connected to the Intake Mani in the picts? Isn't it connected to the block?
Its just a drawing that simplifies the plumbing. Its actually correct. Its just stretched a little, and the valve location isnt exact but its on the correct line.
heres a better diagram of it.
Even after looking through the FSM I have been confused for quite some time as the exact location of the PCV valve, thank you very much for the simple yet illustrative diagram.
Interesting I'll be replacing my turbo inlet hose shortly. I'll look for any residue--I certainly haven't been babying it.
PCV stands for positive crankcase ventilation
The idea is to move fresh air in and contaminated air out. Most engines pull air from the cylinder heads through the engine crankcase and into the vacum of the intake. The vacum is what causes the ventilation when not under boost. With out a PCV all you are doing is letting out excess pressure there is no sweep or POSITIVE flow through the engine.
On a turbo engine the vacum is replaced at times with pressure (boost). The PCvalve closes as to not pressure up the crankcase and blow the seals. Excess crankcase pressure is then vented. As soon as you let off the gas and are back to vacum the crankcase can be swept clean again.
If you have a race car and are primarily in boost and change the oil after every race who needs a PCV.
If your car is your primary mode of transportation then a PCV is a good thing to have since 90% of the time you will be off boost.
My lawnmower has a PCV valve so should my $30000 car.
I have read that NASCAR cars run the engine crankcases under vacum to help with pumping losses.
If looser fitting pistons are installed Then an oil separator maybe needed as the excess blowby can overwhelm the Stock baffling in the valve covers and crank case. This can be installed just before the intake to the turbo.
Discussion Starter #14
Interesting points. Id like to discuss this further.
So are you saying that with out a PCV valve, when the intake is under vacuum, there isnt sufficient ventilation of the crankcase and the heads?
this is the pic of my PCV valve on my intake manifold, 07 STi, the one inside the blue circle
I removed that valve and replaced it with a connector, I get my vacuum/boost line there and my boost gauge. meth kit is tapped on that hose. FWIW since my Crawford turbo kit and AOS was installed, I never saw any oil or oil film in my IC pipes, CP AOS never failed me so far.
I'm about to pull my intake manifold soon and will check the IC pipe again for any sign of oil, and I bet it doesn't have any
How much vacum is in the turbo intake compared to the engine intake?
At WOT there is alittle in the turbo intake and the blowby gasses are pushing their way out of the engine. At cruise the tubo intake will have almost no vacum, and the engine will be producing alot less blowby. The PCV will help pull the bad stuff out.
The idea is to get things moving in the correct direction. Best to keep all that combustion contamination in the crankcase and out of the cylinder head.
I dont know for sure, but with the factory specs/ piston to wall clearance being so tight Subaru must have not seen a need for a separator. Some older factory turbo cars have them. The farther we drift from stock and the harder we drive the more a separartor is needed.
Thank you for this thread!!! I'm in the same pool of plumbing confusion!
I have a pair of catch cans I was about to install, but am now reconsidering picking up an A/O Separator.
How is the PCV catch can (note: not AOS) actually supposed to be routed? Can someone please redraw the diagram with a catch can routing instead of an AOS?
Is it more effective and/or safer to cap off the PCV rather than to intersect plumbing when using an A/O Separator?
and what is the dif between catch can and AOS ?? i thought they do the same job
separating the oil from the air and keep it in the can right ?
