I might have remember $500 off, perhaps improperly rounding. So $2500 in my case.
That did include a DP & GTX Turbo. I didn't want to do this without other changes that would have been a minimum of $1500 above the $2500. I decided no before I got a closer higher estimate that included more parts that I left out. This would have been a bigger and upgraded build. It's what I would have called fully supported. For instance, I might have had to upgrade the fuel pump - again.
Right, I run a Radium surge tank with a 450lph inside. You could easily do an in-tank though, if you're no tracking the car hard and worried about slosh. The need for a larger pump isn't a result of going rotated though, it's a result of more power.
mheyman; said:
Other than that All I am going to say is that Perrin Full Race and tuner kits are both $2000 alone. No turbo.
Right, but the argument is that if you go rotated from the get-go it isn't that much more expensive. The Perrin rotated kit (which I would recommend against anyway) includes up-pipe, downpipe, intake, etc. So if you compare to their non-rotated stuff:
Up-pipe - $250
Intake - $215 (+ $270 if you get their inlet, which you'll want for an upgraded turbo)
Downpipe - $350 (I don't think they offer this anymore, but that's the typical price)
You're already over $1,000 and you're going to pay at least $250 more for an equivalent stock location turbo vs rotated, so again you're going to save yourself less than a grand.
If you already have all the non-rotated supporting mods there's less incentive and more cost to go rotated, but even then it's not THAT much more expensive. Assuming similar power levels and supporting mods of course. There are cheaper ways than going with one of the kits too, I am using a stock location up-pipe still, for example. The adapter was $125.
In the end everyone has to do what makes sense for them, it is just unfortunate when everyone assumes going rotated will cost them an arm and a leg more when in reality, if you do it right, it won't cost much more for an equivalent rotated setup that gives you a lot more potential down the road.
