Has anyone purchased a cooling kit for Cylinder 4 chamber? Seems to be a clever idea as it offers a solution to a known engine issue due to higher detonation risk in #4 chamber, and the install seems straightforward too. I am looking for feedback from early adopters.
I followed several online discussions where people seem to agree that it might be beneficial, but there is an ongoing discussion as to what should be the inside diameter of the cooling hose.
If you have the Dom's kit, what is the inside diameter of the plug that screws into the left head?
If you assembled your own cooling kit, what inside diameter do you have? How/why did you choose it?
Any quantifiable benefits that you could present? tuning impact, etc.
Background info
http://shop.getadomtune.com/categories/cooling.html
Cylinder 4 Chamber Cooling System GR/VA/08+ LGT Fitment
Description
Industry first DOHC EJ Cylinder 4 Combustion Chamber Cooling kit increases coolant flow in the LH head to improve reliability by reducing detonation causing hot spots, reducing EGT delta and improving overall cooling system performance.
This is for all 08+ Impreza and Legacy which require a longer hose than pre 08 cars.
Each kit contains:
1x Coolant pipe assembled with a stainless steel T, high grade silicon hose, Stainless Pinch clamps, Custom machined and anodized 6061 fitting.
Background info
Description
Each kit contains:
