Re: 2008 STi track car Journal
A litle slow in reporting, but I was away for three weeks...
The car did great for two days at Watkins Glen on April 29th and 30th. I ran into Chris Rall an instructor's instructor who had instructed me early on when I first got into track days with my first STi. He installed data-logging gear and a camera on my car. Then I drove and then he drove, so we could compare. I did not have a passenger seat in the car...
First, my new wheel/tire combo and suspension geometry changes:
The front tires only clear by less than 3/16" inside. That is, with 3.4° front and 2.6° rear negative camber and with 3.4" inch outside diameter coil-over springs. The bottom of the spring perch locking ring may be the closest spot.
Front springs are "62mm" nominal and 450 lbs with a 3.4" OD. The fenders are rolled and pulled and everything barely clears. I would estimate that there might be more that could be pulled but not much. I doubt you can fit a bigger sized tire wheel combo on a GR STi without flares. It is tight!
The 285 Hoosier R6's are nice. Chris Rallo, an instructor/sometimes racer, turned conservative 2:09's at Watkins Glen and that was with the car having some minor alignment and braking issues to be fixed. I could not get more than 3.4 degrees out of the left side, but 3.6 out of the right, so I had the aligner do both sides at 3.4. When I got home I ground out the camber plate so I could get more movement and reset both to 3.6°. During that process I had to readjust the toe and I think the toe was out a little too much. I will recheck that.The upshot was the car turned "right now!" It was a little darty. Required a lot of concentration and control.
Given all the changes I made the results were gratifying.
UPDATE, 9-9-13:
Corded my RR Hoosier on the inside. These were my first 285x30 R6 compound Hoosiers and my first experience with the Hoosiers and this soft a compound. Equivalent of six track days, if you count Chris' driving it at Thunderbolt and WGI as one day's wear. Probably a little too much camber in the rear (-2.6) or basically, too few left-handers(?). My impression is it was dragging the inside of the RR too much on right-handers because it just exposed the cord right at the edge and kind of rolled up the rubber, exposing the steel, but not wearing into it yet. Shame on me that I did not catch this early-on. I have a tire temp gauge; just didn't use it!
Surprisingly, the other three look like they have a day or two left on them. Possibly, at 39-40 max, they were a tad under-inflated? There is still some groove left on both sides of the fronts. The LF looks amazingly good and the best of the lot. The extra wear on the RF might be from the left-hand, tire eating, understeering "Octopus" on Thunderbolt. OTOH, It's hard to imagine that the corners of some of the other tires are far behind the RR (like the LR), since inflation was the same, all-round.
