*Most recent update on 6/25/19
Latest tune by Mikey Botti with new IAG Stage 2 Tuff built block:
354hp/395wtq - (364/392 w/o Speed Density)
Original Factory Options
Auto-Dimming Mirrorremoved
Upgraded Security System
Wheel Locks
Mods:
Exhaust- Full-Race 1.5 scroll Header and Uppipe - HPC Extreme coated 2000 Degree and DEI Titanium wrapped
- Invidia V2 Bellmouth Catless Downpipe - HPC Extreme coated 2000 Degree and DEI Titanium wrapped on the bellmouth
- MadDad Whisper Catback: (Full 3" no tapers)
Removed - Turbo XS Stealthback with catpipe and race pipe - Coated HPC extreme 2000 Degree
- MadDad Catted Bellmouth Downpipe - COATED by Jethot exterior only (catted) - Extreme Sterling
- MadDad Catless Essential Downpipe - Swaintech Coated
- APS Header/Uppipe - APS Heatshield Kit & Coated
Turbo - Blouch 2.5XT-R - 8CM Hotside, 3" inlet, Coated
- OEM Heatshield trimmed w/ crucial thermal coating
- Cusco Turbo Heat Shield - fit over the OEM trimmed heatshield
- Cobb 3Port Boost Control Solenoid (BCS)
- Thermotec Turbo Wrap
Removed - Deadbolt 3" 20G TD06 - Clipped turbine, upgraded flapper.
- Prodrive 3port Solenoid
Engine - IAG Stage 2 Tuff 2.5L Subaru Built Short Block
--Manley 99.75mm Platinum Series Pistons, Ringset, Tool Steel Pins and Clips (w/ Coated Skirts and Offset Wrist Pin)
--Manley H-Tuff Forged Connecting Rods w/ ARP Rod Bolts (Heavier Version of H-beam Rods)
--New FHI Subaru Heat-Treated 2012+ STI Crankshaft
--ACL Race Rod Bearings
--ACL Race Main Bearings
--New FHI Main Case Bolts
--ARP Head Stud kit
--IAG Billet Half Moon Seal Valve cover
--IAG Timing Belt Kit (includes Gates racing timing belt)
--IAG Billet Timing belt guide
--New FHI Subaru 11MM oil pump
--Multi-Angle Valve Job, Clean Heads, Deck, Set Bench Valve Lash
--IAG Spec Bore and Hone Block to 99.75mm (Performed on in house Sunnen SV-10) - IAG Black Anodized Oil Cap
- IAG Black Battery Tie Down
- IAG Flat Black Coolant Overflow Cap
- IAG Red Engine Oil Dipstick
- IAG Red Clutch Cap
- IAG Red Power Steering Cap
- IAG Red Windshield Washer Cap
- IAG Red Air Oil Separator Street Series (AOS) - (not yet installed)
- Killer B Motorsports Ruggedized oil pickup
- Killer B Motorsports Aluminum oil pan
- Killer B Motorsports Oil Baffle Windage Tray
- Killer B Motorsports Radiator Shroud
- Killer B Motorsports Alternator Cover
- Killer B Motorsport Dual Washer/Coolant Reservoir
- ATI Performance Super Damper
- Subaru block heater
- STi Radiator Cap
- FilterMag Filter Magnet
- Peterson Breather Can
--8AN to -10AN Earl's Expander
--10AN Aeroquip Socketless Hose Fitting
--12AN Aeroquip Socketless Hose Fitting (90 Degree)
--12AN Aeroquip Socketless Hose - KICS Magnetic Oil Drain Plug
- Beatrush Aluminum UnderPanel - (not yet installed)
Removed - SPT Oil Cap (lost)
- SPT Battery tie-down
Cooling - Koyo "VH" Series Aluminum Radiator
- Samco Radiator Hoses
Engine Management - Cobb AccessPort V2
- Cobb Speed Density w/ MAF
- AEM IAT sensor to be wired and welded into FMIC piping
- Omni Power 4-bar MAP sensor
Intake: - APS DR525 FMIC w/ T-Bolt Clamps
- APS 70MM CAI
- APS Turbo Inlet w/ 3" coupler
- JDM TGV deletes (ported for additional flow @PNPheads.com)
- Engaged Performance Ported Intake Manifold
- Engaged Performance Ported Throttle body + Heat dispersant coating
- Blox Racing 3MM Throttle Body Gasket
- Phenolic Spacers 9.5 MM w/port match
- COBB XLE BPV
- Thermo-tec cool tube over FMIC tubing
Removed - APS BPV/BOV Recirc unit
Fuel - Injector Dynamics 1000cc injectors
- Injector Dynamics Top Feed Fuel Rail Conversion
--Injector Dynamics SFC Feed Line Kit w/ EFI Logics tweaks - Walbro Fuel Pump (new one 11/11/13)
- SX-Performance Regulator
--Aeroquip 6AN Fittings (Qty: 03)
--Aeroquip 90 Degree Swivel 6AN Fitting for fuel return line (Anodized Red/Blue)
--Aeroquip AQP 6AN Black Socketless Hose (For fuel return line)
Removed - Deatschwerks 850cc Injectors
- APS Fuel Rails
Exterior: - Lightwerkz S2000 Retrofit w/ CCFL "Angel eyes" and the works - Big thanks to Caesar@Lightwerkz!
- S203 18" Diamond black BBS RE's
- 235/40R-18 Bridgestone Potenza RE760 Sport XL (Summer setup)
- 225/45HR-17 Bridgestone Blizzak LM-60's (Winter setup w/ OEM Silver BBS)
- JDM Rear Spats
- Prodrive Rear Diff Protector
- Cusco OEM Rear Diffuser Kit
- Authentic STi V-limited lip
- 35% Window Tint all around + 20% on back
- IWSTI Stickers
- Kartboy Exhaust Hangers
- Rally Armor Limited Mud Flaps
- JDM Fogs Lights w/ ION bulbs
- Carbon Fiber NRG Hood Dampers (New Version)
- Hella Supertone Horns (black)
- SubiMods V2 wiring harness for horns including bracket
Removed - Falken Azenis RT-615's
- NRG Hood Dampers (Rusted & broke)
- Bridgestone Blizzak LM-22
Interior: - DEFI BF Amber Boost Imperial - Center hood
- DEFI BF Amber Oil Pressure Imperial - Center hood
- DEFI BF Amber EGT Imperial - Center hood
- DEFI Triple Meter Hood Painted
- DEFI Control Unit II
- DEFI BF Amber Oil Temperature Metric - A-pillar mounted
- DEFI BF Fuel Pressure Imperial - A-pillar mounted
- AEM A/F Ratio Gauge - A-pillar mounted
- Lotek A pillar 3 pod (2 60mm and 1 52mm gauge pods)
- JDM S204 Shift trim and boot
- JDM S204 Red Hazard Button
- Autospeed Dead Pedal
- Valentine One Radar/Laser - Hardwired with concealed display over steering column
- OEM Trunk Net mod
- 2007 STi Limited Interior Trim Kit
- Interior Flaire Red light Interior (switches, HVAC, door panels, keyring, etc.)
- JPM Coachworks Alcantra/Leather mix (Steering wheel + thickened, shift boot (JDM S203 matched), brake boot and center console
- WeatherTech FloorLiner DigitalFit Front & Back
- Diode Dynamics STI Emblems for WeatherTech Mats
- IAG Driver Side Floor Mat Bracket
- SMY Door Striker and Hinge Stopper Cover
- 2015 OEM Auto-Dim Mirror with Home-link and Red lighting
- Rearview Mirror Camlock-to-Wedge Mount Adapter Kit‏ for 2005 fitment
- BlendMount Radar Detector Mount for Valentine One
- OEM Rear Cargo tray
Removed - JDM S204 Full Dash Kit - It peeled all over!
- Escort SOLO S2 Radar
Sound: - Pioneer AVIC F90BT - Sirius/HD Radio modules added
- 120 GB Ipod Classic with Video
Removed - Alpine 9857 Ipod HeadUnit
- Forester Cover (concealing Ipod with headunit)
- 20 GB Ipod directly connected to HU
Suspension: - JDM STi Pink springs
- Ohlins Fixed Perch Struts
- Group N Front strut tops
- Group N Rear strut tops
- JDM STi Titanium Strut Tower Brace
- S204 STi Performance Rear Damper
- Cusco 22mm Front Sway bar
- Cusco 24mm Adjustable Rear Sway bar
- Cusco Rear Lower Subframe Brace
- Kartboy Front Endlinks
- Kartboy Rear Endlinks
- Whiteline Rear Swaybar Mounts
- GT Spec Anti-lift kit
- GT Spec Tie Brace
- GT Spec Rear T Braces
- GT Spec Fender Braces
- Front and Rear Camber bolts (Not yet installed)
Removed - GT Spec Ladder Brace - Hit something on road and this thing was a goner.
- TiC (NOT) Banging Rear End (2 Tokico D-spec rear dampers, 2 Scooby921 Strut spacers, 2 adjustment extenders, 2 new bump stops)
Drivetrain: - Group N Competition Shifter Assembly
- Group N Front Shifter linkage stay bushing
- Group N Motor Mounts
- Group N Transmission Mount
- KartBoy Rear Shifter Stay Bushing - used with Group N assembly
- GT Spec Rear Differential Mount
- TiC Crossmember Bushings
- ACPT Carbon Fiber Driveshaft
- Kartboy Pitch Mount
- TIC Outrigger Comfort Bushings
- ACT Performance Clutch Street Disc
- ACT Streetlite Steel Flywheel
- Motul Gear300 75W90
- Whiteline Steering Rack bushings
Removed - Kartboy Shift lever
- KartBoy Front Shifter Bushing
- TIC Shift Linkage Bushings
- Stock STi Assembly
Braking: - Ferodo DS2500 Front Pads
- Fedoro DS2500 Rear Pads
- Motul RBF600 Brake Fluid
- Technafit SS Brake Lines
- Cusco Master Cylinder Brace
- Girodisc Front 2pc Floating Rotors
- Girodisc Slotted Rear Rotor Set
- Girodisc Rear Titanium Pad Shields
- Girodisc Front Titanium Pad Shields
Misc - NGK Plugs - one step colder
- RACE RAMPS 67's XTs + wheel chock
- Lucas Octane Booster (Use 1 bottle for each fillup)
Removed - Static X grounding Kit
