Torque Specs on Sway Install
2.2K views 10 replies 6 participants last post by  Nixlimited
#1 ·
OK, so Jose and I installed my Strano sway bar last weekend. In doing so, I think we may have over-torqued the frame mount bolts and/or under-greased the bushings, but either way it is making TONS of squeaking noise. So, my two questions:
1. What is an excellent grease to use so that when I re-grease it I will never hear it again?
2. What is the torque spec for those bolts (frame mounts)?
By the way, the bar feels amazing, despite its awful noise.
#3 ·
I mostly need the torque spec above everything else. Im using the grease supplied with Whiteline sways since that's what I have on my LGT.
I don't have this problem on my LGT, but it certainly is a problem in Nick's car.
It wasn't there at first but after a few miles of driving it showed up and now its downright annoying according to Nick.
#4 ·
check your links... but if it's not that.
use white lithuim grease :)
and r u looking for the specs for the D ring, or the mount to the frame?
#6 ·
torque specs
For their bars, Cobb rcommends the both the endlinks and mounts be torqued to 30 ft/lbs.
#9 ·
Brahmzy said:
F the grease n use teflon tape. Lasts for years, silent operation, lubricates perfectly and doesn't need regreasing. Still amazed at folks "greasing their bars." Hahaha. :lol:
I didn't even know the option existed!
