681 - 700 of 1,862 Posts
Discussion starter · #681 ·
For the record. I have had the kit on for about 3+ weeks and I have checked the hoses and have no sign of any gunk. In addition. I have emptied the crank breather can once and drained about an ounce of a milky brown oily liquid. It was very simple to empty the can. I didnt have to remove it. All I did was place a small container under the drain and gave it a few turns to open it. Came back 15 minutes later and closed it. Heres a picture of what I drained. I personally would not want this in my motor. Once again, I havent observed any "Gunk" in the lines yet, and its been COLD here in North Jersey. Maybe a couple of 40 degree days in the last few months. The oil level hasnt moved on the Dipstick. My engine generally doesnt go through much oil during an oil change interval.
Discussion starter · #683 ·
JZeez, where's you pick up your hose? How much was used?
AutoZone has a nice quality Heater hose that is cheap. I dont know the exact amount of hose I used but I would have to guess about 5 feet or so. I will have an exact amount when I put up my write up. Look out for it in the next couple of days. Im finishing it up soon.
Jay
Not sure if this was answered yet, but what is in Lightspeed's catch cans? What sort of filter/media is used? My concern is having anything that can break down over time and possibly make its way into the engine or turbo. I'm definitely curious about the product. Also, other than the valves at the bottom, can the cans be opened up and cleaned out?
Litespeed seemed unsure on this; the best answer I could get was that it has a metal mesh screen on the inside. The question then is: how tight is the wire mesh?, is there only one mesh screen?, etc.
There's a cross section view of the cans on the saichu michi (spelling?) site, but it's a drawing with no details. Your best bet would be to contact Saichu michi directly.
I'm not unsure on it, it is an aluminum mesh, but not overly fine like a steel wool. It is trapped in between two aluminum discs. It does not break down. The cans do not open for cleaning but a solvent can be sprayed in and drained right out.
Nothing will break off and find its way into the turbo, engine, etc.
Adam
Litespeed
Adam
Litespeed
I'm interested in trying your system out but - and please don't take offense to this - I'm trying to see the value of your system over just going with Saikou Michi Co's Split DC3 product (which I believe is what you are using for your cans.)
I assume the routing for the Split DC3 is as simple as:
(Sorry for the crude drawing)
and your setup:
The only real advantage I see to your solution is that you are also filtering air under IM vacuum scenarios (cruise) where, arguably, blow-by is minimal. You've essentially created an enhanced PCV valve by replacing the stock Tee and PCV valve. The routing I've shown above only filters blow-by from the crankcase under boost.
I guess what I'm trying decide is whether it is more cost effective to just buy the Stage 1 DC3 for $130 usd and some hose for $20 cdn. Versus $265+shipping (to Canada) and $20 hose. I do like the fact that you are only allowing clean air under cruise to reach the intake manifold.
That's right, no unfiltered air into the intake tract, catching all three possible routes with only two cans and a better valve.
Didn't you already buy the Grimmspeed thing?
Yes I did but I'm always searching for the most effective setups.
I still have concerns about the Grimmspeed, not so much with regards to how much oil it is removing, but whether it is properly venting crankcase pressure. I also wonder if it is really that great an idea to allow the oil to drain back into the engine, mainly due to water vapour on a daily driver.
I'm sure the GS unit is not allowing oil back into the intake tract and so far it seems to be working fine but there is always that concern at the back of my mind. With the limited amount of blow-by that I see, I'm wondering if I should just go with a simple catch can setup.
The line that comes off the crankcase tee and goes to the check valve on the turbo inlet is a 5/8" hose, isn't it? I noticed that Grimmspeed only uses 1/2" and had hell of a time getting the hose on the tee.
I can sympathize.
1/2" but I provide all necessary fittings to make it easier. I've considered offering a 3/4" version for the crankcase side can for those running big boost with forged pistons (where you'd see more blowby) and this would mean a bigger can and valve too. The current version is working nicely for stock and medium sized turbos.
After a bit of searching, I now see why your solution appears so expensive. Those ET-Performance KrankVent valves are expensive! Good lord.
To me this is when a catch can is needed most. I would have to say that you are definitely right that blow-by is minimal under vacuum situations, but isn't that the situation that a daily driver sees most of the time? Just trying to throw some ideas out there to stir the pot :)
Yeah I guess it depends on whether you are cruising on the highway or constantly moving from stop-light to stop-light, though even that depends on how you drive and how your throttle and boost target is setup. I used to run a map that almost always had me in boost around town. Very fun to drive, not so good on fuel economy. :lol:
Yes, I'm using quality components, and if you compare the Litespeed price to what you get with some of the other kits available, it's clear I'm marking up substantially less than most others. As I've said before, the retail price of the components of my kit would be more than what I charge.
I would imagine so :eek:! Sounds like that would have been a good map for auto-x.
For me, I do a combination of both types of driving, highway and stop-light to stop-light so I want to catch blow-by on both ends of the crankcase vent, vacuum and boost.
I decided to look at my GS AOS after around 1000-1200km, in particular the hose connected to the intake tract:
I couldn't see any oil in the intake line, only a very tiny bit of dampness in one end of the line (I checked, it didn't feel like oil, more water than anything.) Overall it seems to be working fine. I don't see any sludge or other issues and we've had a few days of -12C.
Unfortunately, I didn't get a chance to check my IC. I plan to do that soon when I install my GS EBCS.
I'm actually going to try Litespeed's setup now as I'll likely be sending my engine to Rallispec for a build up. I was debating whether to get the Saikou Michi CCs and run my own routing, leaving the crankcase-to-IM as-is, and only filtering on the turbo inlet side, but I still wonder under DD with forged pistons if it would be better to filter everything.
My biggest concern with the GS, which you just pointed out, is that I'm not sure it will relieve crankcase pressure properly or sufficiently with a larger turbo setup and forged pistons.
