Spun Rod Bearing, Something Important You Should Know
1 reading
91K views 33 replies 14 participants last post by  RallyLegacy
#1 ·
I have learned some expensive lessons lately, and thought it would be nice to pass them along so that you may not make the same mistakes I have.
Stage 2, 07 STI broken ring lands.
Over the winter from 2010 to 2011 I installed new Mahle pistons. To do it properly I split the block so that the cylinders could be honed to clean them up. New rod and main bearing were installed just because I was there. Engine ran great and didn’t leak at all. A 20G turbo was installed and the tune was done in April/May. I was daily driving just for the fun of it. It was done and life was good.
4 days before my first track day of the year..............
I spun #3 rod bearing on my newly rebuilt engine. At first I blamed Cobbs Flat Foot Shifting as the problem started right after it engaged. http://www.iwsti.com/forums/ecu-tun...-electronics/218716-can-cobbs-ff-shifting-cause-engine-damage-when-not-use.html After more research I have concluded that there were 2 issues and both centered around my poor assembly and the sealer I used. Cobbs FFS was just the straw that broke the camels back.
In all reality there is a short list of things that can cause a spun rod bearing.
Lack of oil
Poor bearing clearance (to big or small)
Improper assembly
Poor bearing construction
Detonation.
Subarus have a poor reputation when it comes to rod bearings. It is why the oil pumps have gotten larger and the crank shafts have been nitrated.
I have read a lot on checking bearing clearances. Let me let you in on a little trick I learned when I was learning how to rebuild diesel truck engines. If its not broke don’t fix it. The bearings and wear looked fantastic, so why go through all the time and trouble checking it all. Stock crank, block, and bearings is what I had and it was in great shape. I just replaced like for like. In other words bearing clearance was not the problem....... sort of.
Poor bearing construction; I spent $380 for a nice shiny OEM set. Definitely not the problem.
Improper assembly; Assembly was checked and rechecked many, many times as I was meticulous with the reassembly. Besides I flogged the engine for 300 miles before it started knocking.
Detonation; Absolutely no sign of it at all. Tune was very conservative and the logs had no knock. Pistons looked great except for all the bearing material embedded in the coating.
Lack of oil; When changing the oil just before the spun bearing I did notice metal flakes in the oil pan. Not good, but it was the first oil change after rebuild. Examining the block after splitting it in half I noticed a BB sized piece of sealer in the oil passage. At first I thought it may have fell in on disassembly. No way could that have gotten in there. The oil passages from block half to half looked clear and OK (no sealer hanging on the O rings).
The oil pump was another story. Even though I tried to go sparingly on the sealer I also did not want a leak. When the pump was bolted to the block a lot of sealer squished out all over. The clearance between the pump and block are machined almost perfect and you only need a skim of sealer between them. Very tricky.
After thinking it over I concluded that the oil filter should have captured the sealer before it got to the engine. This may normally be the case, but I did not break the engine in. I tuned the engine just after rebuild. This meant driving hard and at high RPMs. High RPMs causes high volume and pressure from the oil pump. Subarus oil filters are designed to bypass the filter at a specific pressure (DP). If you are still with me I now conclude that the excess sealer in the oil pump broke off and blew through the oil filter bypass and into crank main bearing #3. There it had no where to go, but in the way. Main bearing #3 feeds rod bearings #2 and #3. This is why these are usually the trouble children of the rod bearings. They both get fed by only one source unlike #1 and #4.
In a panic I ordered a short block and proceeded to assemble the engine. The above scenario bothered me so I did some searching. I found mention of Anaerobic Sealer when doing Subaru oil pumps.
What makes this sealer better is it will not harden in air. The sealer can be slopped on and will not form hard balls that can be broke off and sent through the engine. A little piece of mind when rebuilding an engine.
Anaerobic sealer is thin so that it does not cause clearance issues. I believe that the sealer I originally used could have caused the block halves to not compress fully and possibly cause the crank main bearing clearance to be to large also.
This would also starve the rod bearings.
I have also switch to 40 weight oil as this was recommended by the engine builder.
$3500 later and I can drive my car again, and doing a real break in. This to me is the most important reason to follow the engine break in procedure. At least the filter should not be bypassed and can catch all the nasty break in material.
Hope this helps you avoid the same problem. Hopefully this solves mine.
VP
Reactions: NewBoy
#2 ·
The original sealer that I used was Honda Bond. This is a great sealer and for someone that assembles Subaru engines all day would work great. Rookie me just applied it way to thick.
The new short block was built by Vigilant Motorsports.
Noisey CP pistons, but so far its running great.
#5 · (Edited)
Feel you pain, I had #3 rod bearing go on me at a track day on my stg. 2 factory block. Oil was full and I pitted within 20 sec. I rebuilt my new engine with a track block from vigilant motorsports and a 30R. Before the 30R install I broke the engine in (1200 miles) and put it down to install the 30R and some other engine and suspension mods. Its going in for a tune with in the next 2 weeks in Chicago. (1500 break in miles) I used Hondabond for the pan (Killer B pan and oil pump) and had no issues. We will see how the engine takes the 30R:devil: The CPs are a little bit more louder than factory but just on warm up. Once its warmed up no extra noise. Great choice with sean at Vigilant as he has always taken the time to answer my calls even on weekends. I believe him to be one of the best Subaru builders out there. Great guy for service as well.:tup::tup:
#6 ·
I used Honda bond on the oil pan also (new engine). I do not see an issue there, but the oil pump was a bad move on my part. I used the anaerobic on the front cam journals, and Honda bond on the valve cover seal.
So far no leaks :knocks on wood:
I asked Sean a few questions and he was real good at getting back with me.
I can hear very very slight piston slap/knock when she is warmed up, but actually this maybe a good thing as I know there is plenty of room when I hit the track.
#7 ·
Hard lesson learned. But the truth is, if you would have done a 25min first start up, then changed the oil and filter, and again at 250 miles then again once more at 1000 miles, I could bet that you would have been fine. Though, I see excessive sealant usage in almost every engine I tear down (boxers or other). And that may have been the root cause, but if you would've done a proper engine break in, I'm sure the outcome would've been different.
On that note, if the pump is new and the matting surfaces are true, then I recommend just using a thin layer of wicking loctite or similar.
I am glad to hear that you are back on the road again though! good luck!
-J
#9 ·
I have changed the oil on this new engine like you have stated, but only because it had metal all through it. I cleaned everything up, but that stuff can really hide. If you think about it, it is possible even the proper break in my not have caught the problem. The piece of sealer my not break off until there is alot of oil flow (high RPM). Or it may sit at the bottom of the filter and get sucked up later. You odds are much better breaking it in though.
First engine I have been through with a glue on oil pump.
The only problem I have now is being hyper sensitive to every little noise and scared to drive it hard, which was not a problem before. :)
#10 · (Edited)
VP, glad to hear you know a root cause. Sorry it happened at all, good information here, thanks for posting.
#14 ·
I believe I got lucky when I spotted the sealer. I remember looking at it and telling myself no way nope that couldnt happen. It took a while for it to sink in.
Then it comes in a rush, "you idiot!!" you should have known better.
#12 ·
I have a 2 day trackday in July, if she lives through that I will not be paranoid any more.......
Maybe :)
#15 ·
Update,
Vigilant Motorsports short block.
Just got back from 2 days at the Glen. Engine ran great, but what really suprised me was after 4 hours total track time I only burned through a half quart of oil. I brought a gallon and did not have to use any.
Still noisey as heck when cold, but she is holding together.
#16 ·
I know this doesnt pertain very much but I feel like one of you could help me out and you may know. I just rebuilt my 2.0,05 wrx, that I bought blown up with a spun bearing (cyl 3). Details short and sweet everything you should know.
2.0 OEM subaru short block from dealer
Original heads gone over at a machine shop cleaned, milled, valve job.
Used stock turbo from a childhood friend 5k miles
Cobb Stage 1 Tune
TGV deletes with rod and sensors
Short ram intake
Down pipe, 3'' exhaust
Codes: Crank case ventilation ( i dont have it plugged in because that plug is broken, but its there)
No oil cooler (getting new one just have it bypassed now for initial start)
2 questions
After first start up and idle with very light throttle blips for about 15 minute s total. Engine makes no internal noise and is very quiet for a subaru. The oil seems very metallically, as if someone dropped a gram of gray powder into the oil and stirred it around, when you rub it between your fingers you cant feel it. Is this normal for a new motor after initial start up????
Engine hesitates very slightly then revs up when you blip the throttle, I have changed to new oil since then and did some more idling and blipping. It revs up well right after the hesitation????
#17 ·
The gray in the oil could be from the assembly lube. If you hold it up (the oil) to a light does it glitter?
The hesitation could be alot of things, but I would start with checking all the intake hoses, and electrical connectors.
A short drive may tell you more.
#19 ·
nice right up man... I'll be sure to ask the shop what type of sealer they'll be using on my car. From the sound of it and what the shop said without opening her up. I spun a bearing last night :( I was looking at the vigilant blocks, but might just rebuild mine with forged pistons and a few other upgrades while they're in there. We were tuning when this happened and only at 13 lbs of boost. No signs of knock or anything. Kind of strange in my situation with the load being so low. I'm thinking my oil pick up shit the bed. i'll soon see as that will be replaced as well. Anyhow, thanks for the info and good luck.
#20 ·
6 trackdays, and 4000miles latter and everything is still holding together. Pretty happy with the engine and tune.
Not real happy with the piston noise even when its warmed up, but its more of a paranoid mental problem then an issue. Oil consumption is almost nothing as I can do a 2 day track event and not add oil. No AOS or catch can either.
Good luck with your build. Start a thread when you find out what went wrong.
#22 ·
Yep, I can agree. But whatcha gonna do? Goes with the program, right? Remind me what piston brand again? And what size are they?
#21 ·
To the OP: Just a couple comments...
1. After the rod bearing failure, during the rebuild did you replace the OEM oil cooler? With a new one? Or at least a used one which has not been involved in an engine failure? The reason I ask is that the OEM oil cooler can't be satisfactorally cleaned after an engine failure, and if the old one was reused metal will continue to come out and contaminate the oil in your rebuild.
2. Some Subaru performance engine builders have said that the STi OEM bearing clearances are too tight. Not a problem under normal street driving, but under track conditions at extended periods over 4k RPM the bearings can overheat and problems can begin. This happens even though the overall 'bulk' oil temperature reads OK on the oil temp gauge. One of the suggested "cures" for this is to use the ACL "Race Bearings" which have some extra clearance, which in turn allows more volume oil flow past the bearings, and thus helps to control bearing temperature.
#23 ·
Item 2. Extra clearance in terms of numbers = what? thousandths or mm please.
#30 ·
Right. Nothing at all wrong with the factory bearings. I would say an advantage of the ACL race brgs is that with a new crank the ACL brgs are sized to give +0.001" additional clearance. That was the decision I took on my rebuild. In my case I stayed with the 10mm pump, and have plenty of oil pressure.
#33 ·
Oil was full.
At most it was down 1/4 quart.
With the broken rings I would go through a quart in 4-5 20 minute sessions(about one day). 2 days would have been 2 quarts.
I did a track day at Mid Ohio in the middle of May and have yet to add oil. The level is above 1/2 way on the stick.
#34 ·
I just got back from Mid-Ohio. Maybe we will cross paths in the future.
Another benefit to running an AOS is that you can overfill your oil to help to eliminate any chance of starvation or drop in pressures in high G turns. Any oil pushed out the heads will just get returned to the pan. If you have a pressure gauge, try to glance at it in a sweeper and see if it drops. If it does you could probably benefit from an AOS and overfilling the pan. I usually aim for the hot full mark-base of twist cold and then somewhere around the top of the twist hot.
IMHO anything at "full" or below is too low for track use.
