Hi there,
Well, when I came back from work yesterday, a 65km ride, the DAM dropped below 1...
Should I worry?
Usually, I only saw Fine Knock Learn going down to -2.80, same for Feedback Knock.
Since the DAM dropped to 0.938 (or even 0.875), the Fine Knock Learn fluctuated a lot.
This morning, DAM was still at 0.938, even after a 40 minutes drive. The Fine Knock Learn got to -7.74... :|
Could this only be bad gas? Something worse? Should I do an ECU reset by reflashing the same map?
The only thing I change in the car, a few months ago, was the air filter. I installed a K&N.
I run Cobb map Stage 1 - 91.
It's a 2016 STi with 41986 km on it.
Thanks in advance for your feedback.
SomeOneQC
Should I worry?
SomeOneQC
