Roof Rack - Subaru+Yakima+3m ppf. Lots of pics
27K views 46 replies 20 participants last post by  wundej
#1 ·
I recently installed my Subaru base bars, Yakima Fatcat 6, and some 3m clear bra.
I knew i wanted to put some clear bra down under the base bars because I can't imagine them not scratching the paint once it gets messy out. This was my first time doing any type of clear bra/vinyl work. I made patterns with the rack off the car, cut them out, and went to town. I cut one large piece for each mount, then cut a flap in it so I would be able to index it front/back and left/right at the mount location. I then removed the backing of the ppf, used warm water in a spray bottle on the back of the film and on the car. Set it on the car and double checked the alignment by carefully setting the rack on it (this is much easier w/ 2 people). Removed the rack and resprayed again. Then started to squeegee the water out and make it nice and smooth. Once i had both sides of the rain channel smoothed out I took a razor blade and split it in 3 parts, removing the middle section. Squeegee'd the edges near the channel down and it was off to the next one.
I'm really happy w/ how it turned out, but I'll probably redo 1 or 2 of them next winter.
Tips: 1 make two patterns (1 for front, 1 for back). Then trace out the other side's pattern from the first side. Then you'll have nice uniform pieces. Make sure the car is a decent temp. It was about 55F in the garage and it would have been much easier if it was around 70F. Get a 2nd set of hands to test alignment. I was a little off on the front passenger side (almost too far back, but still protects).
The Subaru Base Bars are great. Super easy to install, 10-15 minutes after I had the clear bra on there.
Fatcat 6: Universal mounting hardware almost always sucks. It was a pain to get them mounted properly with just myself doing it. Get 2 sets of hands and it'll be pretty easy.
Two things I would change...
1. They could have used a rubberized cover on the bottom clamp (just like the top) to make it a bit nicer, I'm sure that with some bars that would be an issue though.
2. Get bolts in a length that is in between the short and long ones they give you. The short ones were too short, long ones are way too long.
Wind noise: Definitely can hear it with boards on after you get over 45-50mph. At 65-75 it's not terrible, but don't expect it to be quiet. I hear more noise on the passenger side (hinge side it on drivers side).
Board mounting: Luckily my wife and I are both short. We both ride 151's, and my bindings just barely fit in between the racks. This is great because there is an equal overhang on front/back. Don't have to worry about hitting the antenna either. They also have a feature to raise the rack a bit for binding clearance. I haven't tried mounting the boards with the bindings down yet, but I think there may be room w/o raising the rack.
Gas Mileage: With 2 boards on (bindings facing up) I got around 21mpg driving from Allentown to the Poconos. With no boards, just the bars and fatcat I got around 25mpg from Quakertown to West Chester. Pretty much all highway between 65-75mph. I'm pretty impressed, I thought it was gonna be worse. I'm sure if I put another 2 boards up there it'd be at least 2mpg lower.
Now I gotta find out which bike mounts I want and order some of the SKS lock cores....
Thanks to S2theI for his thread, it made me decide on the fatcat.
#3 ·
That's about right...Even without the racks on anything over 70 will start to really impact your mileage. 18-19 is really good at that speed.
I'm probably going to get the Thule fairing next year, that should only help the wind and can't hurt mpg either.
#4 ·
I have the exact same setup but with the a Thule wind fairing, there is almost no wind noise at any speed. The other nice thing with the Fat Cat is that you can actually carry 4 boards, there is enough clearance between the roof line and where the boards mount so your bindings fit. I had the OEM Subaru snowboard carrier and there is no way you can fit 4 boards, even two wider boards was pushing it...
Also for the screw ends, I found some 1/4" screw caps at the Home Depot that fit on perfectly. It finishes the install off nicely. Also when you're putting on or taking off the FatCat it has a tendency to roll and at some point it will roll enough to jam a screw end into your nice painted roof, the caps help!
Seems like we need to 3M the whole car!
Thanks
#5 ·
I thought about it, just too freaking expensive. When I get the fairing I'm going to probably put clear bra across the front of the roof where it sits on it.
(ps. I only dropped the carrier on the roof one time during the install:eek:...luckily it feel on the round top part, not the bolts. I wanted to punch myself, I definitely cursed at myself a few times after that. I'm thinking of just cutting down and chamfering the bolts I'm using now.)
#14 ·
I can fit my 159cm Supermodel, inside its padded board bag, flat in the back of my GR (barely). I'm 6'0" and do not have to move the seat to accommodate it.
However, since I transport people and skis/boards, I bought the factory crossbars too. I have an old Thule Big Mouth ski rack (or whatever it's called, part #x724). The cool thing about the Thule ski rack is that it integrates with the T-rail of the factory crossbars for a super low-profile look, no 'reach around' grips. You just need the XAdapt2 kit for $10.
#25 ·
Haha.... Yes it most certainly does! I have had two minor interferences between board and rear spoiler, nothing major, just have to be careful. The other option is to position the boards so more overhang is in the front, but that not only looks ridiculous, it is probably really noisy and would be annoying to look at whilst driving.
#29 ·
awesome love the Yakima rack... I still have the old school wind noise busting one..lol
#33 · (Edited)
Just for reference for those who wondered if the board would fit in the hatch...
My board is a 156, fits perfect forward, or sideways with room to spare, i could probably fit a few more in there as well, and just throw a towel on the nose so if it slid into the back of the seat there would be no scratches..
i could probably fit over 4 boards facing the seats side by side, theres lots of ways to rig it in there, and even keep 1 of the back seats availible too for a 3rd passenger
#43 ·
You are talking about the plastic key (the one they give you 2 of)? If that's the case, they aren't a standard 12 point like a socket. They have a bunch of different profiles so that one person can't just go to anyone's car w/ stock bars and take them off with their key. That's why they tell you to mark down what # key you have in case you need to replace it.
