WRX making screeching noise
1 reading
7.9K views 12 replies 3 participants last post by  mattman
#1 · (Edited)
Hey guys,
I'm not sure where I would post this, but I need help. I don't know what it is, and I need your guys input on what you think the problem may be.
I have a 2005 Subaru WRX. Something crazy just started happening a couple days ago... I have recorded a video so you guys can hear what noises it's making and maybe help determine what the problem may be. Its like a scratching/screeching noise
Other things besides the crazy noises is:
-It's harder to get the car to start moving.
-When the car is screeching in 1st/2nd, it feels like my car is stuck
-I have to gas harder to force it out of the screeching sound to start driving
-It usually happens only in 1st and 2nd gear when driving from a stop.
-In 3rd-5th gear, the car will make random shutters like a heart beat almost.
-After driving, I smell some weird burning..
It has around 799xx miles so almost 80K miles. I've owned the car for 2 years and 2 months. I bought it with 59K miles and I have changed the oil every 3-4K miles with full synthetic mobil 1 oil. The last time I changed the oil was about 2500-3k miles ago, so it is due soon.
I believe it may be the clutch going out? But I didn't think the clutch would make these noises..... Kinda scared that this is a very serious problem. Please help me out with some info!
The video is uploading right now. I'll post it as soon as it's uploaded
#4 ·
you need a clutch. the screech you're hearing is the throwout bearing. the smell and the behavior of the car are consistent with that.
#6 · (Edited)
#8 · (Edited)
i would get the flywheel resurfaced. there is no reason to replace it unless its damaged.
i am not a fan of lighter flywheels, myself, but lots of people are. do a search and weigh the pros and cons.
see if rallysport direct can help you. mention my name and you'll get 15 bonus points and a trip to texas.
#10 ·
Ok. Replaced clutch today (including pilot bearing, throw out bearing, clutch itself and plate, and flywheel ok with resurface) and did everything to my knowledge correctly. But now I CAN'T get into gear when the car is ON.....wtf?? I can shift into gears when the car is off.. but when I turn it on in neutral, I can't put it into gear.
I can however, start the car in 1st gear, but the car will automatically start rolling as if the CLUTCH wasn't disengaging/engaging all the way... it's like if I floor the clutch pedal, the trans is not disengaging all the way. And when I try to shift while clutching, it'll grind gears.
Lastly...the noise (screeching) is still present. Ugh.... IDK what to do. Please help someone.
#13 ·
BUMP.... Re-did things and the TOB wasn't seated properly. Fixed it and now the clutch feels great. But the car is still screeching and jerking when I accelerate. I can barely get the car to 5mph before it starts jerking and screeching at me. IDK what it is.. Need help I'm going INSANE
