Nice to see something of mine raised from the dead. For the muppets in this thread that keep dropping "it's illegal" blah blah blah. Just know that every day you drive you are breaking the law or, as you would put it, doing something illegal.
1of100, thanks for the reply. Still would love to be able to have my fogs on with my marker lights. Have you done this?
Ok here you go. You'll want to do this on the passenger side so you have more room, again you only need to do it on one side. Remember your fog lights will be on anytime your parking lights are on and you can't turn them off. When you turn the high beams on the fog lights will stay on.
Start by removing your air intake scoop. Next locate the wires for the parking light (you won't be able to see the parking light ) one black and one red. Use a chunk of wire long enough to go down to the fog light. Using a splice connector splice the chunk of wire into the red wire on the parking light. Now get on the ground and remove the 2 snap clips and 1 10mm bolt to gain access to the fog light. Remove the fog light to give you more room to access the wires. Find your chunk of wire coming from the parking light. The fog light has two wire, black and white. Use a splice connector and splice into the white wire and test. If it doesn't work you may have missed the wire when crimping the connectors, check and retest. If all is good reinstall the fog light and air intake scoop and your done.
Red wire on parking light.
Wire going down to fog light
White wire on fog light connector
