Background and symptoms:
I have been searching on mostly Nasioc for an answer. As some of you know I have a leak in my Headers collector to UP flanges. I will be swapping the headers out soon and want to make sure that this will fix my problem. But could this leak be causing a misfire?
I start the car and it runs fine at idle when cold. After it warms up to normal temp, I can feel an intermittent vibration and hear a "puh" noise now and then from in the cabin and if I put my ear near the exhaust pipe.
I also have an afterfire if I push it hard out of 1st and into second or if I rev the car.
I dont think it is a boost/vacuum leak as I hold pretty steady at about -9 to -10psi vacuum per the AP at idle.
My AFR once warmed up hovers around 14.7+/- .3, but occasionally will spike up to 16 which also seems to be a symptom of the "puh" noise.
My RPMs also like to dip from 750 down to the mid to high 600s and then rise back to 750. when they drop is when I get that "puh" sound which is accompanied by the vibration in the engine.
I am not getting any CELs.. at all..
I do not get any hesitation or issues when on the throttle be it a little bit cruising around or at WOT and anything in between. It is only at idle.
Mods:
APS CAI 65mm
Maddad UEL headers and UP - with a leak
Cobb Catted TBE
Walbro
NGK Copper spark plugs - w/about 4k miles on them
APv2
Protune/streetune
Running only 93oct
What I have done so far troubleshooting:
1.) I have swapped to brand new spark plugs with no change in idle, so I swapped back to the older plugs as they still have some mileage left on them. I also made sure to regap them to .028" - no change
2.) pulled the MAF and cleaned it with electical cleaner, twice - no change
3.) cleaned the air filter - no change
4.) pulled the oil cap and checked for smoke - nada
5.) checked the exhaust at start up for smoke (white/blue/black) - Nada
What I suspect:
My research is showing that it could be my pre-exhaust leak, that I hope to have fixed by next weekend or a possible o2 sensor problem. I wondered about the o2 as I have been fooling with my headers for the last 3 weekends and may have damaged it. I have read that because the car runs closed loop when initially started the 02 sensor isnt used. After the car warms up will it use the o2 and if it is bad could be causing this issue.
My plan thusfar:
1.) compression test - but is this needed since there is no smoke from the oil fill neck?
2.) swapping headers back to stock with all brand new OEM gaskets.
3.) boost/vacuum leak test.
Any ideas on what is causing this or possible fixes/things to check that I have missed? Should I log the car at idle and post that to be diagnosed?
Mods:
APS CAI 65mm
Cobb Catted TBE
Walbro
APv2
Protune/streetune
Running only 93oct
What I suspect:
My plan thusfar:
