HOW WOULD YOU LIKE YOUR DRIVE TODAY?
_____________________________________________
What’s the lay of the land?
What kind of weather are you having?
What’s traffic like out there?
Confused as to which of the WRX STI SI-DRIVE, DCCD, and VDC settings to use?
I came across this on the web and thought I would post it here as it explains the VDC, DCCD, and SI-Drive. This is everything you need to know about the VDC, DCCD, and SI-Drive.
I think anyone who has an '08 STi needs to read this as this explains all of these 'gadgets' pretty well. It also shows you when you should switch each on and what setting it should be at.
For your convenience I saved the web pages as images and will post all the information on here.
Here are the original links where I got the information from if you prefer going to the website instead:
BLUEPRINT: TAILORING THE STI – VDC, DCCD, AND SI-DRIVE
DCCD - DRIVER CONTROLLED CENTER DIFFERENTIAL
SUBARU INTELLIGENT DRIVE (SI-DRIVE)
YouTube - Subaru Impreza STI '08 JDM and DCCD use
