Varis Widebody WRX - APM Racing Rotors!!
162K views 670 replies 79 participants last post by  champGR8
#1 · (Edited by Moderator)
2005 Subaru Impreza WRX 2.5L (5MT)
Exterior:
· Varis Super Taikyu Wide Body Kit
· Varis Super Taikyu Wide Front Fender (25mm Wider)
· Varis Super Taiyu Wide Rear Fender (30mm wider)
· Varis Carbon Rear 3 Piece Diffuser, Hyper Canard & Attachment Cover.
· Prova JGTC Style Street GT Wing (1400mm - Wet Carbon)
· JDM Subaru OEM Rain Visor
· Hankook RS-2 Z212 (265/35/18)
· Bee Racing 18X9.5 +23 (Front) 18X9.5 +8 (Rear).
· Custom Red 4 piston Brembo Front Big Brake Kit with Hawk hps Brake Pads
· Custom 2 Piston Rear Big Brake Kit with Hawk HP+ Brake Pads
· Techna-fit Stainless braided brake lines
· 5000k HID Low beam conversion
Interior:
· Blitz Mirror Drive Boost Gauge with zerosport style Custom Gauge pod.
· Blitz DTT turbo timer
· Personal 350mm Granita Leather Steering wheel
· NRG Short hub and Type 2.5 quick release
· Pivot engine start button
· Open source engine Management
· Bride Cuga CFRP Seats (RED)
· Kartboy short shifter + harden shifter bushing
· Garage Spec shifter extender
· A Spec Titanium shift knob.
· Glitter red Cusco 6 point roll cage.
· Carbing aluminum rear bulk head cover
· JVC MP3/CD Head Unit
Engine & Drive Tran:
· Garage HRS Titan Cooling Panel
· Beatrush Pulley Cover
· Custom turbo heat shield
· Vf39 Turbo kit.
· Grimspeed 3 port boost solenoid
· Power Enterprise 800c Injectors
· Polished Intake Manifold
· HKS SSQV Blow Off Valve
· Apexi Short Ram Intake
· Hybrid EJ257 STI Short Block
· 2.5 STI Oil Pan and Pick Up Assembly
· Modified High Flow Oil Pump
· Denso supra fuel pump
· Gramlight 57 Dragon Titanium Exhaust
· Helix JDM Length Downpipe
· STI Catless UP-pipe
· Grimmspeed Phenolic Intake Manifold Spacer
· Greddy Front Mount Intercooler
· Koyo Racing Aluminum Radiator
· Samco Sport Radiator Hose
· Relocated Optima Battery in the Trunk
· Tein Hood Damper
· Exedy Stage 2 clutch with light weight flywheel.
· Cusco Engine and Transmission Mount
Suspension:
· Meister R Inverted Coilover Suspension with 8kg / 6kg springs
· Carbing front strut tower with Master Brake cylinder Brace
· GT Spec Antilift kit
· Whiteline Roll Center Ball Joint and Tie Rod Extender
· Carbing Front Strut Tower
· Cusco Rear Strut Bar with V-Brace
· L&E Quick Steer Steering Rack
#9 ·
Re: Kenji815 Journal - Sneak Peak wheels and seats
looks nice....you should of got gias though...keep up the jdm work ;)
Save
#18 ·
Nice work!
Save
#23 ·
Re: Kenji815 Journal - NEW SNEAK PEAK WHEELS!
LOL picture will be coming soon.
I took some time to clean up my nardi wheel today.
It's 330mm deep corn sport rally suede.
Suede is known to get clumpy after few days of use from oil released by your hands..
I had this wheel for over 1 year now.
It looks brand new after it's cleaned and brushed.
#26 ·
Re: Garage Spec's EJ257 - Fully polished Blitz Type 01 Revealed
wow, that is a sweet car man. i really love the seats too. if they didn't clash so bad with my 06 interior i might grab a set for myself. keep up the good work making us all look good!
You have insufficient privileges to reply here.
