I have a quick tuning question that has been bugging me ever since I started to tune my own car. When shifting, the ECU quickly turns off the injectors between shifts and when I floor it entering the following gear, AFR drifts from ~11.1:0 to 20.0:1 and it obviously takes a bit to get the AFR back into the target range. I've never noticed knock due to this but as you can see from my log sample, my AFR is 13.7:1 while running 3.0g/rev, which obviously concerns me.
This is a stage 1 94 octane tune, on a 2008 STI, stock intake, stock DP/CBE, 1-step colder plugs. So far I've managed to hit 3.7 g/rev in 4th with the stock exhaust in -7c weather, but I digress.
Is this something that would be solved by increasing tip-in enrichment? Is there another approach to address this issue? I believe I understand what is causing this issue: a lack of fuel on the intake manifold wall so when the throttle snaps open, it causes a lean condition until Tau is restored. Is that a safe assumption?
Thanks for any advice. Much appreciated.
Log sample:
Log sample:
