21 - 36 of 36 Posts
Respond on hollow and solid bars. Hollow bars should resist more than solid bar if you compare the same diameter, and it is lighter, so in a sense better. But unless they are really made for strict racing application, the thickness for hollow bars are not that uniform, and could make different reactions. I use both 27/29 whitelines front and back. 29 in front and middle setting at back. with heavy duty whiteline endlinks. I had 24-26 on the rears before and expected oversteer when i changed to 27-29 rears but I had my car aligned properly, and it feels more balanced now, and more predictable. I combine this with my tein flex and set it lower than recommended in a sense. I have the stock 17" bbs and measures 25" fender to floor in the front and 1/2" lower in the back. Might sound low, but the ride travel is the same as 14" front, 13.5" back fender to center wheel, because i lowered the strut body instead of the spring seat.
I play around with my EDFC settings. most of the time, i drive on the FW 15/15, 10/10 on corners and 6/6 on track. I have been using this setup for almost 2 years and happy with it. regards
STI.KID said:
Guys and Girls!
I have been driving myself nuts reading about sway sizes and what works best. I am driving mostly street. I will do a couple track days but not enough to worry about a huge bar. I have GF210's and 18x8.5 wheels with 235/40's for tires. I was in contact with a guy from flat iron's tuning by the name of Jon and here is what he had to say. It is a little technical but seems to make sense... He has sent me Whiteline 22mm adjustable fronts and 24 rear. I am trying to figure out if it should be the other way around like Clint reccomends and if so why? Thanks for the help in advance
What size (stiffness/regitity is what is actually important) you want to run front as aposed to back, depends on how your car is currently behaving under cornering. In general, you run more anit-sway on the end of the car you want to REMOVE traction from. So if your car is understeering (lack of front traction, pushing through corners) what you want is less traction in the rear, making the car more neutral. In that scenerio, you would run a larger anti-sway bar in the rear.
If you have oversteer problems (the rear skids out a lot) you want to run a stiffer front sway bar to remove traction at that end, again, bringing the car to a more neutral and predictable state.
That answer works for most cars, unfortunately the STi isnt one of them. The camber curve on the front of the STi is VERY poor and to keep your front tires out of positive camber stiffening is necessary. I gained a LOT more front and rear traction when I went with stiffer bars. I got neutral handling and much more traction.
Matters not. When you upgraded your bars equally on both sides, yes you did reduce body roll of the vehicle, which is what an anti-sway bar does fundamentally. The anti-sway bars work relativly to the anti-sway bar on the other end of the car. So for example, you feel your car is relativly neutral, that is fine. But, now... increase the stiffness of JUST the rear sway bar, and you will see that the car will tend to oversteer a little easier. Increase the stiffness of JUST the front sway bar (relative to the rear) and you will see that the car now understeers a little easier.
What you need to do is the following:
A) first figure out how much body roll you want to eleminate. This will determine how stiff, in general, across both axles, you should run.
B) then you need to figure out whether you want to dial in less or more of either under or over steer based on how you drive and how the rest of the car is setup.
"B" can only be accomplished by either owning multple stiffness anti-sway bars, or having sway bars you can adjust relative to eachother.
stiffer front sway = more understeer
lighter front sway = less understeer
stiffer rear sway = more oversteer
lighter rear sway = less oversteer
stiffer front and rear sway (relation stays the same) = less body roll
lighter front and rear sway(relation stays the same) = more body roll
that seems to be the exact opposite of what the sti suspension and handling gurus are preaching.
why else would a bigger front swaybar be such a great handling mod ?
if what you're saying is true, we should be getting <19mm front sways.
J.
J.
Hard to say. I am brand new to the STI, but these are general rules on how anti-sway bars work, and I have never heard of these rules flipping 180 degress for ANY car. The only thing I can predict, is that a large front sway bar, by itself, will on it's own reduce body roll giving the sensation of better traction. My guess is, if that if somebody is having understeer problems were to increase the front stiffness a little, but increase the rear by a larger %, than the understeer would be neutralised (at least by some).
J.
Exactly my point. And whether its logical or not it works. If I put my stock FSB back on I am gonna be more prone to understeer because (due to body roll) I cant keep a decent contact patch on the front tires. This has been widely debated, ask any of the real gurus (of which I am not). Stretch, Mykl, TiC, RCE, Whiteline, the list goes on.
Yeah its a trade off man....Added weight transfer to the tire but also increased contact patch. Most agree the advantage offered by increasing your contact patch over comes the the added weight loaded onto the tire. There is a theory that understeer may also be attributed to an abrubt change in front spring rates when you hi tthe bump stop. If a sway bar works the way it should it will help combat thos issue too.
But the point is you need to get some freakn negative camber up there and sustain it around the corner period. Its hard to do in the STi. I know my favorite mod is chewy granola bars but my second favorite is negative camber:tup:
quoting Clint (TiC)
read his whole article in one of the stickies on top of this forum.
Front sway bar – why bigger is better
Our cars are set up with a McPherson setup up front. Like all suspension systems on cars they have their plusses and minuses. Some of the plusses for the McP setup are weight, and simplicity. The big con, that concerns us and front sways address, is poor dynamic camber curve.
See, what happens is this – when you compress the outside front corner (the one that’s loaded when in a turn) the suspension compresses as it should. When it compresses the dynamic camber curve causes the wheel to roll more toward positive camber. Push more and the more it rolls toward positive. This is bad because you start to loose grip as the inside edge of the tire gets “light.” Ideally you want the full contact patch evenly on the ground (or close to evenly) to maximize grip. This is the reason that folks try to run a decent amount of static negative camber. In other words, if you start with negative camber when it rolls over toward positive camber you have enough of a camber “budget” to allow for more contact patch on the ground.
So, where do bigger front bars come into play? Well, the front bar acts as a spring (torsion spring in this case) to help hold the static camber curve as you compress the front suspension. As you compress the loaded corner the bigger bar will resist that camber roll over to positive on the loaded corner. This is why bigger is better.
Ok, so what size should I use? Well, it really depends upon what you want to do. My thoughts are this – HUGE bars (i.e. The strano 32mm bar or the whiteline 27-29mm bar) make for every quick turn in, but darty handling. The moderately huge bars (i.e. Whiteline 24-26mm bar) make for very good turn in, but not so darty so things are smoother, more predictable and more controllable.
Hey, that’s great Clint, but still what bar should I get? These have been my suggestions to folks:
For autocross or somewhere where you want stupidly quick turning that is a bit darty then I suggest the HUGE bars.
For something like canyon driving or street only use (or track work with nothing but nice sweeping turns) I suggest something like the 24-26mm adjustable bar.
J.
The trend here is to increase the front as much as possible, while keeping the rear at around 24mm. This makes sense considering the BEST camber you can get out of a stock STi in the front is around -1. Some people have trouble getting -.5 in the front, while the rear is always around -1.5.
Has anyone tested that? ;)
Ok, yes, that makes total sense if that is an issue that the car's natural geomatry has (I am not yet familiar with STI suspension quirks). But I think it is best to not confuse why and how the anti-sway bars are doing what they are doing. In the cases you are providing here, a much stiffer front sway bar is reducing body roll in general, which is keeping the front suspension from compressing as far, which is keeping the car from rolling to a posative camber. You will feel this affect most if braking into a corner. My guess a larger than stock rear anti-sway bar will have the same affect on negative camber when neutral or accelerating through a corner.
My point is, increase anti-sway throuought the car to minimise body roll and camber change, increasing tire patch in a turn. But once there, if you need to dial up or down understeer or oversteer, you have to know how the sway bar on either end of the car will affect it.
So what I have read on the sticky (in short) is "Use larger front sway bar to decrease understeer", which to me, isn't right. It should be "Use larger front sway to reduce body roll, which will keep more contact patch on the outside corner". Once you have adequately reduced body roll (and therefor camber roll), if you want even LESS understeer... you wouldn't go with an even LARGER front sway, you would go with a larger rear sway to reduce traction at the rear (gives the feeling of better traction at the front)
I think we are all saying the same thing, I just think it is the "why" that is incorrect.
Sounds accurate to me.
21 - 36 of 36 Posts
