41 - 51 of 51 Posts
I guess I won't be trying 23/21... the softest hole (21mm) on the the Super Pro rear 22mm extends past the adjustable range of the Kartboy endlink, and so cannot be reached. In fact, it isn't physically possible for ANY endlink can reach the softest hole. This is the same thing that happened with the Super Pro 24mm rear bar: I couldn't adjust to the softest hole.
Basically, the rear Super Pro bars are only 2-way adjustable, whereas all 3 holes on the Whiteline bar had no adjustability issues at all. This kind of pisses me off... :mad:
WL KLC 39 links will work...they are what I use on both front and rear. (Adjustable spherical links.)
Whiteline KLC39 Front Anti Sway Bar Link Assembly Rod End Mitsubishi CLR | eBay
Or these will work too.
Cygnus Performance | Late Model Import Parts STi, WRX, BRZ - FREE SHIPPING Whiteline Spherical Bearing Endlinks Rear 08-12 STI / 08-12 WRX Part # KLC066
Discussion starter · #43 ·
You'll have to buy the Super Pro endlinks that now exist. Ask for a discount or try trading in the Kartboy ones for a refund.
23/21 is quite good though with stiffer springs, let me tell you!
The limitation on the Super pro rear links are that they aren't height adjustable, to my knowledge, so they aren't as good if the car is going to be corner balanced or need to adjust loading side to side.
On my car, there's no way physically possible for either the Kartboy or the Super Pro endlink to reach the (S)oft hole on this swaybar. The soft hole extends past the lower control arm; in order for an endlink to reach, you'd have to rotate the bar upwards so that the softest hole lies directly over the mounting range of the endlink. But then you need an endlink that's A LOT longer in order to reach. Wouldn't this change the swaybar geometry, resulting in an even softer bar?
The swaybar stiffness is determined by the distance from the center of the bar (straight section before the bends) to the hole you select, within reason a longer swaybar link wouldn't affect stiffness setting. The WL KLC066 is only slightly longer than stock but it is much thinner than the Kartboys. I had the same issue with mine so switched to WL spericals.
The rest of the setup, especially springs, will influence how the swaybars affect overall handling. People on '10-, '11+, RCE, swift, eibach, KW, AST, etc etc will have such differing spring rates that the effect of the bar on total wheel rate will be all over the map. It would be more useful to look at overall wheel rates rather than just swaybar thicknesses/settings.
However, swaybars are much more efficient at reducing roll, and will do so with almost no impact to two wheel bump and will only have half the spring rate for a one-wheel bump (when compared to running a spring of equivalent rate). So in a way, getting required wheel rate in roll through a swaybar would be beneficial from a suspension compliance standpoint.
If I understand correct main reason for this thread is avoid understeering on GR when day driving. I'm tired so I didn't have motivation to read everything in thread already. Still I need to put input :lol:
I have done multiple modifications with suspension, stiffening and tyres. Very similar than others here. Although some more jdm rather than RCE.
Still after modifications most of people here seems to forget or underestimate driving technique. You have to understand that you are driving 4wd car. There are diffs on center and both ends. Even there are computer controlling them, there are lag. When combining lag of diffs and turbo and weight transfer you will ultimately encounter understeering if you haste when going in corners.
So what I really try to say here is, that you need to turn proper speed in without brake after skid. Then you need to steer smoothly in and wait for weight transfer and diffs to understand what is happening and tyre to respond. Once you know you are good to go you can open throttle. If you managed to do everything right at this point STI will handle exiting corner like a dream from this point. Also you need to know what is condition of surface including +/1 angle of surface.
Of course there is lots of other things to understand when crushing 0,010 on race track but I think most of people doesn't understand what kind of car they are driving when they are driving 4wd. IMHO. No offense in anyway.
everything this guy says is gold!
41 - 51 of 51 Posts
