Street tuner maps.
1 reading
1.9K views 18 replies 5 participants last post by  kccobra
#1 ·
Anyone have a map that could get me started with my tuning. 2006 sti
I have installed
perrin gt35r turbo kit, complete
perrin fuel rails
helix 860cc inj.
hyperflow v2 tmic
walbro 255
Aquamist alky injection
turbosmart full recirc bov
I just want a map to get me started, if anyone has a similar setup that would help a bunch.
Thanks
KC
#4 ·
kccobra said:
OK thanks for your help.
On the map, is it a money issue, or ???
For some people, yes. For others no.
Fact is, I have yet to hear of anyone personally tuning their own FP Red setup. Has it happened? Probably. However, the majority of people with big turbos get tuned by a 'tuner'. Couple that with the fact that a lot of people who get custom tunes don't even have StreetTUNER (they are just running an AccessPORT with a ProTUNER map) and you are left with a very very small population of people who have StreetTUNER and a custom big turbo map that they are willing to share. A fraction of those aren't even on the internet.
t
#5 · (Edited)
I would start with a rescaled stg2 base map. Adjust the scaler for the injectors. Use the stock MAF and wastegate boost to start with. Copy-paste the Dynamic advance A map over the B and C maps. Zero out the dynamic advance tables above 2.5 engine load and smooth out the transition. Run race gas or a mix of race gas and 93 for your initial pulls, for safety in case it leans out or something. If the car feels good and your datalogs look good, start pulling timing from the base ignition map (above 2.5 load, where you zeroed out the dyn adv maps) and add it to the dynamic advance maps.
This is how I've tuned my car, I am running basically the same setup but with a fmic, pe 850cc injectors, and an smc alky kit. I max out the stock MAF around 21psi, I'm just about ready to switch over to the BigMAF. The alky isn't spraying either yet. If you search nasioc for "GT35R and datalog" you will find some logs to compare your datalogs with.
Good luck. Be careful - you're playing with fire. Go slowly and let out if your AFR's or EGT's look at all funny.
#10 ·
I don't mean to hi-jack the thread, but someone's comment above raised a question. As a tuner tunes a car with the street tuner software, can he see EGTs easily to help ensure safety of the tune...I know that dyno software allows for afr readings, etc...but I am curious about egt
