So while driving today I noticed that I wasn't getting any boost from my turbo. A little details about the car... 35K miles on it and completely stock with exception to suspension. So upon starting my car the boost gauge shows between -.01 and -.02. It only hits 0 at WOT. Also when putting the car in neutral i normally run idle at about 750 RPM. With this problem it would constantly drop down to just under 500 rpm and the car would slightly shake. Almost feeling like it was about to stall, then all of a sudden the rpm's would jump back up to about 1250 without even a slight touch to the gas...
Any ideas on what could be causing this problem? I havent looked under the hood yet to make sure everything looked connected with no issues but let me know any ideas or things that might cause this. Its been a little colder here the past few days but nothing more than its been all winter. About 10 degrees over night and its been running fine in negative temps before today
Thanks for your help,
