I know the Subaru specified rotor thickness limits are as follows:
standard for front rotors: 30mm, service limit: 28mm
standard for rear rotors: 20mm, service limit: 18mm
This means that you are only allowed 1 mm of rotor wear per rotor side which seems to be a very small amount, especially for street use. I measured my front rotors and I am at 27.5 mm which means that I already below the official service limit. I have only used my car for daily driving and I am coming to the end of life on my second set of OEM pads which were the only ones used on these stock rotors.
So the question is, what is a safe reasonable limit for rotor wear for street use, or should the Subaru specification be gospel? Would I be nuts to not change them when I change my pads next?
