this part is for the budget builder that is looking to go rotated for the fastest and cheapest way that i could think of. A stock flange to t3 adaptor that rotates the turbo to the perfect position while retaining the stock up-pipe. these adaptors are made out of 304 stainless steel (flanges and pipe) and tig welded.
for this first batch i will only be making the adaptor itself and not the downpipe (need to recoup my investment first). i can also provide buyers with all hardware associated with the install from gaskets, studs, nuts, bolts, Wastegates, Full line of Precision turbochargers, oil feed and return lines. these adaptors will be offered in two ways, with a 44/38mm wastegate flange and without the flange for those who already have an aftermarket up-pipe with an external gate******
*there will be an option to have the t3 inlet flange tapped with studs for an extra $20
price will be $225 shipped for the adaptor +$25 with wastegate flange 38/44mm tial vband
i hand port these also
i can also make them for a tial turbine housing
