Hello,
I'm looking for any advice regarding my rear passenger side rotor which is stuck due to a stupid mistake I made. I was working on pulling the rotors and forgot the parking brake was on when I got the the first rear rotor (passenger side rear). I tried to get it off without realizing the parking brake was on.
Once I realized, I released the parking brake but I guess it was too late. The rotor is stuck on and for the life of me I can't get it off. I've tried the following:
1. Set and release the parking brake multiple times to get it to free up.
2. I tried removing the dust boot rubber plug on the back side of the hub/wheel and using a screw driver to rotate the wheel with teeth on it as I read that can help release a stuck parking brake. This didn't help at all either and the wheel also seems to be pretty seized up.
3. Pounded the rotor (they are being re-used) with a hammer from the back side to try to hammer it out. This didn't work, but the rotor does move out towards the end of the lug bolts it just doesn't go far enough to come out. It also doesn't hammer out evenly because there is only one section open from the back side to hammer the rotor.
I also noticed it looked like the parking brake drum pad that presses out against the inside of the rotor is stuck and also comes out when I hammer the rotor. I can't see a lot but it does look like this is happening.
So right now I'm stuck and in need of any advice as to what to do next. If anyone has any helpful advice it would be greatly appreciated!
Thank you!
Thank you!
