so i snapped mine while changing the rear diff oil.
there was actually 2 nuts there, 1 for the sensor seat, 1 for the actual sensor. i removed the actual sensor since i only had a 19mm deepsocket and nothing fit the other nut. while re-tightening it per 60nm torque spec i guess they were referring to the second nut and not the actual sensor.
anyone know the part number for the temp sensor,
also whats the size socket for the main nut that goes into the differential where the sensor sits. i tried a 21mm as the largest size i had and that didn't fit.
