Just to provide some information regarding STI damper/spring parts number that I came across when researching for S206 chassis parts. You'll notice the damper/spring part numbers are not the same for every kit even though they may look the same. And the only publicized spring rate by STI that I know of is the lowering spring option for 2008 WRX STI (Type A/B).
Here we go:
R205 SPRING AND STRUT KIT / STI Performance Package Damper Kit
Front damper RH ST20310ZR040
Front damper LH ST20310ZR050
Rear damper ST20365ZR000
Front spring ST20330ZR020
Rear spring ST20380ZR040
*Note: Looks like there is specific package for 5 doors:
PKG1100006
STI - SPORT PARTS - WRX STI
STI NBR Challenge Bilstein damper kit
Strut (F) RH 20310ZR020
Strut (F) LH 20310ZR030
Shock absorber (R) 20365ZR010
Coil spring (F) ST20330ZR020 ※
Coil spring (R) ST20380ZR050
<tS>
Strut (F) RH 20310ZR040
Strut (F) LH 20310ZR050
Shock absorber (R) 20365ZR020
Coil spring (R) ST20380ZR040
<tS type RA>
Strut (F) RH 20310ZR080
Strut (F) LH 20310ZR090
Coil spring (F) ST20330ZR050
<S206 damper set >
Strut (F) RH 20310ZR060
Strut (F) LH 20310ZR070
Shock absorber (R) 20365ZR030
Coil spring (R) ST20380ZR080
Lowering spring
2008+ (Type A and B)
Front spring: ST20330ZR010
(5kg/mm)
Rear spring: ST20380ZR020
(4kg/mm)
2011+ (Type C and D) Manual transmission:
Front spring: ST20330ZR030
Rear spring: ST20380ZR060
2011+ (Type C and D) Auto transmission (A-Line for JDM EJ257).
Front spring: ST20330ZR040
Rear spring: ST20380ZR070
My impression with STI is they very specific when it comes to part number so I believe the damper/spring settings are different for each part number. I could be wrong of course.
Source of information:
STI S206
Japanparts.com
sti.jp
