Have the tuner do the plugs and comp test. Just cheaper, easier and quicker that way.
I agree with OMG, only do it if you going stage 2 or higher. Again i agree with ENDR, while they are working on the car have them do a smoke test for leaks. If they can you might as well have them do a leakdown test. Some shops have the equipment some don't. Just another piece of mind and assurance that your car is A OK.
I know my local tuner will NOT tune it until they do a comp test so they don't waste your time or theirs.
This is a quote from the tuner local to me:
"There are a few things to consider that could help maximize your performance on the dyno. A 3port boost controller and a fresh set of 1 step colder spark plugs will ensure optimal performance with the current modifications on the car. Spark plugs can make a drastic difference if they are old and have a worn gap. It could be the difference of being able to push 17psi to being able to push 20psi which would essentially equate to 30+ ft/lbs of torque in the midrange. Also with the extra power you will benefit with the 1 step colder as it is putting us just one extra step away from detonation."
They did tell me that having a catless DP and/or a intake really won't make bukus of a difference and not worth buying if you already have a good DP and the stock intake.
As stated above email/call them and ask all questions because EVERY tuner is different and each has their set items to maximize THEIR tuning process.
As for an extra car, you could take 2 so you don't have to hang around or call someone local and go mess around. However I suggest, if they will let you, hang around and observe what they are doing. It's not just to keep an eye on your car, but you could learn some things you didn't know. If you're like a lot us, your not only protective of your car but love learning about it and watching the events unfold.
