MMMM... Titanium!!!!!! NEW brake shims!!!!
2 reading
1.5K views 4 replies 4 participants last post by  Turninconcepts.com
#1 ·
We did a run of Titanium brake shims, and they are now in stock, on the shelf, and ready to ship.
Price is $100 per set, and shipping in the US is FREE!!!!
  • Each set gets you four shims - enough to do both front calipers.
  • Brembo fitment
Material is Ti-6 and each shim is 1mm thick.
To get your TiC Ti shims for your Brembos click here.
Brembo:
#4 ·
TheKiffer, Copy pasted from their website:
Brakes are a tricky thing when it comes to heat. Some of the heat you generate you WANT to transfer, and some of the heat you generate do you NOT want to transfer.
One of the most important places where you do NOT want it to transfer is from the pads into the caliper pistons. Too much heat and you start to cook fluid, seals, and dust boots. Once these are cooked it's time to replace them, and quite honestly the time spent bleeding the brakes after every run or rebuilding calipers after every event is time that can be spent on something else.
We can help cut down on that heat transfer with our new titanium brake shims.
  • In each kit you get four shims (enough to do both front brakes).
  • Each shim is 1mm thick
  • Material is Ti-6, offering some of the best heat insulation available to keep heat from migrating from your pads to your calipers.
Save
You have insufficient privileges to reply here.
