just installed my k@n typhoon
Ok thanks i was always curious. What is the added benefits though?
When you match with the clutch engaged (neutral) you're spinning up the layshaft. When you match with the clutch disengaged you're only spinning up the engine, so obviously there's a considerable difference in the amount of rotating mass.
Without synchros you have to double-clutch to match. My opinion is that it's not asking too much of modern synchros to reconcile the mass of the layshaft and gearing, and my experience is that it's faster to match single, because the engine spins up faster by itself.
I think Nick's position is that the double-clutch match is always best. There was a brief exchange on this in another thread a while back. Certainly there is an elegance about double-clutch matching, and kudos to anyone who can pop them off spot-on every time.
Most of the time when I double-clutch match with the STi, I get about the same amount of resistance at the shifter as I do on a single match = very little. Sometimes I can get that near-perfect alignment that Nick was/is talking about.
From a practical standpoint, I think double-clutching is a good idea if you have a lot of RPM's to make up - eg. skipping gears. In terms of time, all of this is going on in the breaking zone, so it seems to me that the breaking is the limiting factor.
Certainly an interesting topic.
