Grinding/Scraping Noise
13K views 12 replies 11 participants last post by  mikelichtenfeld
#1 ·
It only occurs when taking a tight turn up a incline. So far it's only happened turning into my job site from the main road, turning inside a parking structure, and entering a gas station. All of these places have a incline. I know the noise is loud enough that people outside can hear it (breaking necks the wrong way:( ) This is my first AWD car, so I'm curious if this has something to do with the diffs or if my car actually has a problem. This grind doesn't occur other then going up mild inclines, and I leave the DCCD in auto.
#4 ·
I had same noise under same tight turn slight incline condition when I forst brought car home from dealer at ~ 15 miles. Thought I'd scraped the exhaust tips but making a slightly wider turn no noise. I've heard same thing in my truck with limited slip rear differential so I figure it's the STI's front LS differential. Seems to have quieted considerably after the first several hundred miles.
#5 ·
I have that noise too. I think its the skid plate because my driveway is gravel and when I occasionally get the sound of the drive way you can hear the gravel breaking loose to something hitting it. Not the differential. You wanna hear the diff noise? Throw your dccd in full front manual, and take a turn in a parking lot... Apples and oranges.
