I'm just curious because I'm doing a fuel injector install right now. How many of you reinstalled your Brackets of Death after you finished installing larger injectors?
If you unbolt the the TGVs from the heads you can lift it enough to get that bolt out.How the heck do you remove this bolt (passenger side near radiator) with the hard line in front of it?
Image Link
I used search on two different forums, and from what I can tell, if I had a GD STi I would be done by now because the write ups are pretty thorough for those. GR Injector write ups leave much to be desired.
This is the last bolt I need to remove this bracket, and I'm at the point where I want to kill something.
