301 - 310 of 310 Posts
Sorry to resurrect an old thread.
I just finished installing my STi Genome gauges (boost, oil pressure, oil temp and water temp).
All light up and do the ceremony sweep on start up but my boost and oil pressure gauges aren't functioning with the controller. Any ideas what this could be?
Just wanted to check something. The OP mentioned that the Imperial DEFI oil temp gauge was 1/8 NPT, so you would need a PT to NPT adapter. That's only for the BF gauge, right? It sounds like the DEFI Racer series uses PT for both imperial and metric, so there's no need for an adapter for that, right?
Also, would it be safe to run a T fitting on the front gallery to run both a pressure and a temp sensor off of?
Well, I changed my Genome controller out for a V2 Defi Controller and now boost gauge works but the Oil Pressure still doesn't.
Sounds like it might be a loose connection an the clip. Do a tug test on each wire to see if one is loose, it'll feel like its stretching cuz the wire is broke under the wire surround.
Bringing it back! I've had my defis in for 5 years now and suddenly the other day they stopped working. When the lights are on the link meter lights up but nothing from the gauges. Has anyone else come across this issue. Did the gauges blow? Did the meter fail? Help!!! I checked all my wiring and didn't find anything.
