Camshaft Position Sensor Code + Rapidly Burning (& dirty) Oil = Ringland Failure?
13K views 7 replies 5 participants last post by  Drewzn
#1 ·
Hi guys,
I have posted on this forum prior with a detailed summary of my car's history, but I will shorten it even further as I don't believe too much is relevant now that I am having symptoms.
History
2016 WRX STi bought new, always reasonably well maintained, ran with a catless downpipe and Cobb Stage 2 OTS tune for ~ 3/4 of its life on and off (I put it back to stock when I thought it was going back to the dealer after 3 year lease was up). I ran it for a few laps on a track just to see how it would go but it overheated quickly as it was about 105 degrees out that day. Saw the engine temp warning and slowed down immediately, engine came right back down to normal and all seemed fine. I most recently did a full service on it over the winter just before 50k miles, including spark plugs and putting the catless DP + tune back on.
Problem
Fast forward to beginning of August, she throws a crankshaft position sensor code (P000D) so I check the oil and its super low, like not even sure it was on the dipstick low. Throw a quart in and drive home.
A week later the code is still there, although intermittently, so I try an oil change as I read dirty oil can gunk up a cam sensor. I collected an oil sample but I don't have any previous baselines and haven't yet sent it out as I am still looking for recommendations for a service to use. Filled her up with Royal Purple and cleared the code.
A week after this and the code is still there intermittently. One time during start up the car seemed to be vibrating from side to side at idle, I goosed the throttle and when it settled back to idle the vibrating was gone. A day later I took her to the shop.
Here is where it gets weird. The shop called me convinced I hadn't changed my oil in 15k+ miles based on the sticker on the window and the fact that there was barely any oil and the oil that was there was really dirty.
Now I could be an idiot and underfilled the oil a couple weeks ago (doubt it) but I for sure checked a couple days after I changed it and it was clean as could be. I have only driven 200-300 miles or so since then. I asked them to do a compression test and it came back 105, 105, 110, 110, so seemingly OK.
The shop wants to throw a new cam sensor on, change the oil, and clear the code. If I do this and put it through my Mechanical Breakdown Insurance I will save a few hundred bucks even on diag costs as they only pay for diag if there is an issue to fix (I think). Alternatively I can ask them to do a leakdown test, but this will just increase my diag bill drastically and likely would not get covered by the insurance if I ask for it (at least that's what I think, if I am wrong please let me know).
What are the chances I have a blown ringland?
Should I fix the cam and monitor it daily, or should I ask for the leakdown test now?
Seemingly aggressive oil burn aside, "very dirty" oil after 2 weeks can't be anything but blowby, right?
Thanks all in advance.
Tony
#2 · (Edited)
What are the chances I have a blown ringland? Seemingly aggressive oil burn aside, "very dirty" oil after 2 weeks can't be anything but blowby, right?
yes
especially with the vibration.
ADDED: To many unknowns to now anything for sure. This is common when trouble shooting via Ethernet with things and people you don't know.
What is excessively dirty oil? Could it mean glitter?
Did you actually change your oil? For all we know you changed your coolant thinking it was the lubricant.
All I'm saying is that all to often things don't turn out as we on-line would expect, and often that is because we have to make so many assumptions . . .
So I believe oil consumption is "always" a improperly routed PVC system, or valve seals, or blow-by?
A leak would loose oil but isn't really consumption, and it has additional symptoms.
owns 2020 Subaru STI
Reactions: alaskapilot737
#3 ·
Thanks for the reply.
Where I am at now:. The shop didn't want to do the leakdown test for some reason so they threw a new cam sensor on and changed the oil and I took her home. I've driven her a total of 80 miles since to and from work with no issues, checking the oil each day and still looking full and like new.
After my drive home last night however, I hopped back in the car a few minutes after parking her and started her up, and the vibration was back. It's a very distinct vibration rocking the car side to side, which makes me think it's related to a cyl not firing or something similar.
Not sure at this point, but I will keep you guys posted.
Thanks.
#4 ·
Agree
#5 ·
UPDATE
The vibration only happened that one time mentioned in my last post.
I drove her successfully for another ~3 months, 1000mi, when it popped the same code. This time however, it was for a camshaft position sensor in the DIAGONAL position as the first one.
Oil still looks like new. Only 1000mi on it after all. In general, I would say the oil consumption is not anything past what you would expect for an STi at ~57k miles.
I cleared the code and stopped driving her except for here or there. In 2 months I did under 100 miles. Then we had a overnight blizzard and I couldn't help myself, put a good 50 miles on her in full drift mode. 3 hours spent at 3500-5000rpm with next to no load (there was a perfect 1-2" layer of snow EVERYWHERE) should have been enough to trigger any issues once again, but nothing happened.
Since then I have driven her with no issues for another 50-100miles? I looked into the construction/functional design of the camshaft position sensors, and from what I understand they are simply Hall effect sensors with the tip poking into the oil channel right in front of the camshaft. I don't know the gap measurement but would imagine it is between 30 to 50 thou for the Hall effect sensor to function.
At this point, I am wondering if I let it go longer than I thought without an oil change the first time a code popped (~6000mi/10months) and the oil got very low and dirty, depositing debris in front of or fouling the Hall effect sensors. So when the shop changed the first sensor, it corrected that problem, but there was still a little bit of circulating debris or something that got stuck in a DIFFERENT sensor (it has only had 2 oil changes since the oil got low). Then, after running the motor at varying and high RPM speeds, it cleared out whatever schmoo was causing the Hall effect sensor to throw an error.
What do you guys think? I would imagine that I have driven enough miles at this point (>100) that the cleared code would have come back if the issue was still present.
Any feedback is much appreciated.
Thanks
#8 ·
Have you ended up fixing the problem? Has it come back?
A year ago I had a P000B/D code, whichever it was, it was the exact same thing as you. I had just gotten the oil changed by Subaru themselves to make sure I wasn't in the wrong. About one thousand miles after the oil was changed, the code came back. The reason they didn't change anything other than the oil was because they suspected the code came on due to poor/dirty oil in the system. We ended up changing the camshaft pulley and the code disappeared and never came back.
HOWEVER, one week ago, the same code came back but driver side this time. I am at a lost for words. We are now suspecting poor maintenance by previous owner which could've caused a lot of parts to go bad, but THIS bad...? Anyways, this time it came back on approximately 300 miles after the oil change. I had changed the oil myself, looking on forums to make SURE that everything was fine and I knew what I was doing, which is not really a magic trick... it's literally changing the oil. I did everything right.
I am now at a point where I literally don't know what part to change. We got a new cam sensor that we'll try and see if that sorts it out. Oil is perfectly fine and the levels are also good.
#6 ·
Theres alot to speculate here right from the beginning of this thread. One fix isnt always the answer across the board for every car. P000D can be due to many things from bad sensors, oil control valves, avcs, wiring connectors and oil. Just because you went 100 miles or so doesnt mean its "fixed"
None the less, i would keep a very close eye on your oil levels and lower you OCI down. Personally, i wouldnt be doing 6K OCI.
