i know they make an oil for break in purposes but does this additive do what break in oil is supposed to do? i am having doubts since i want to add the correct stuff into my motor in order to fulfill the break in process...
From the factory, the engine is run for awhile using break-in oil prior to installation, usually about the duration equaling a thousand miles prior to drain and factory fill of standard oil.From what I've read Subaru doesn't use break-in oil, just conventional oil from the factory (Nisseki-Mitsubishi M1K 5w-30).
From here: Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! - NASIOC
