So I was doing some searching around and I found a video on draining the transmission gear oil which says to use a T55 on the plugs, but he clarified in the comments that it is actually a 10 mm hex bit. I went out and bought a set of hex bits and I used 10 mm and it is constantly slipping to the point where if I continue to use it, it will completely strip the plug. Can anyone verify the correct bit to use to drain the filler plug and drain plug on the oil pan side? I know the clutch side is T70, but the service manual doesn't mention the correct bit for the other two plugs and I don't want to risk stripping the plug by trial and error. I already have to buy a new drain plug because it is pretty messed up.
Thanks!
EDIT: The part number for both of these are the same (807018060).
Transmission Gear Oil in the Service Manual
It might be a 14mm hex bit. My set only went up to 10mm so I'll have to go out and buy it and test it out.
Thanks!
