i was just wondering if i can use aftermarket lugnuts on my OEM BBS wheels on my '08 sti? thinking Rays or something similar. i know that there's issues with fitment, see:
+1 for the McGuards... I have them on both of my cars. They fit great, offer great theft protection and look great as well! Couldn't be happier, and I also got both sets from lugshack.com![]()
I got the same ones from the same place for my GR but in gold.So, just to make sure before I order....these are the only black lug nuts w/ locks that will fit my OEM BBS Wheels for an 07 STi? They are McGard....
McGard Spline Drive Black Lug Nut Installation Kit With Locks 12 x 1.25
I too have been using the McGard spline drive lugs on both me OEM and aftermarket wheels. It works just fine.
Yes, I have been using them since I got the car, they work fine.
When I was buying wheels from Fikse,I sent them a stock nut,a Subaru/McGard locknut,and a McGard spline-drive nut. Fikse told me that all three had the same correct cone seats and could be used interchangeably
Yes.
Subaru uses a M12x1.25 nut with 60Âş cone seat just like aftermarket tuner wheels. The face that meets the wheel is a bit smaller then aftermarket nuts, but all else is the same.
I've been running black McGard spline drives on both my OEM BBS set as well as my SSR winter set essentially since I got the car. The McGards are nicely made with a two piece design - the cone seat doesn't rotate with the rest of your nut as you torque down. So far the black finish has survived two midwest winters with nary a tarnish to be found.
OEM Subaru lugs (at least the locking ones) are also made by McGard if that means anything to you.
Go to the The Lug Shack for decent selection & prices.
Would this hold true for '08+ OEM STi 5-spokes? Due to an unforeseen OEM lug nut shortage, I would like to use my McGard spline drive nuts until the replacement OEMs arrive.You really have the option of stock or Mcgard. Our lugs have the 60 Degree taper or conical seat. but the factory BBS lugs have a shorter seat length. Our thread pitch is 12x1.25. McGards are very nice and are high quality also. They are available in gold, black, chrome and they also make the custom sti logo lugs. They offer several layers of theft prevention as they are spine driven and are available with locks. They also have the spinning seat which helps to not scratch your wheels. I purchased mine from the lugshack.com. They have great prices and fast shipping.
gold mcgards
Chrome Mcgards
Totally agree. I'll be getting McGard's, but I just wanted to post this for the more adventurous guys.You can try it but I would stick with McGard since others, including myself, use them with no issues...unless you want to be a test subject.
Did you ever find an answer to this? I was just looking at them for my '12 STi. Just got my OEM BBS wheels powder coated black and the lug nuts are the last thing on the exterior of my car that isn't black or red.I realize this is an old thread, but I just went to the Lugshack site and I was going to order the McGard Spline Drive Black kit and noticed the statement:
**Lug nuts are intended for use with aftermarket wheels only. (Tuner wheels or wheels with very small lug nut holes.)?
Does this mean they won't fit my OEM BBS Wheel?
Thanks!
I vouch for these working as well. Use them on my winter / all season / summer wheel sets.I ran the Muteki spline 12x1.25 lugs this last summer w/ the BBS wheels. No problems to report :tup:
Hello me,Just received some Muteki SR's... then saw this thread. Was going to use them on some '16 OEM STi base model wheels.
Now I'm a bit concerned about the seating surface... if they might gall or get that ridge on the seat surface like pictured earlier in the thread.
Anyone double check theirs from the backside?
I'm sure they look ok when installed, but can't see inside.
To be completely safe, Id only run the OEM or Mcgards on an OEM wheel no matter the brand.
The issue is the seating of the lug to the wheel. Moteki lugs are going to have the same taper as any tuner lug.
