Okay update at post 19:
http://www.iwsti.com/forums/3227546-post19.html
Issue now is full throttle compressor surge in 5th and 6th gear only. 4th gear is fine.
I recently had the pleasure of purchasing another IWSTI user's STi which was impeccably maintained, tastefully modded and runs beautifully. However, I am coming from a 2004 STi that only had a catless downpipe and Cobb stage two tune, so I am slightly inexperienced with some of the issues that may arise in a car as modded as this one:
My new car is currently running:
Rallispec Street block (cp pistons, Manley H beam rods, ARP heads, ACL race bearings etc)
FP 20g 8cm^2 hotside recently rebuilt by Blouch
Perrin FMIC
DW740cc injectors
Perrin big MAF intake
Turbosmart recirc/BOV
TGV deletes
Prodrive ECBS
TurboXS V2 catless bellmouth DP with 4" opening
Turbo XS catback w/ regular tip
Tuned by Bren tuning in Maine (conservative 17psi)
And the list goes on. My issue is that at highway speeds in 6th gear, if I give it anywhere from 5-25% throttle at about 3k rpm, I get some pretty solid compressor surge when I lift off. this happens in all gears, more pronounced in the upper ones. Sometimes its bad enough that it jerks the car a bit - throwing it off balance. However, there is no compressor surge when giving it the beans, in any gear.
I have spoken with a few fellow STi owners and they claim to feel this in their VF39 STis, albeit to a lesser extent (I dont feel it in my stage two 04 sti). I also am going to try adjusting the tightness of the turbosmart recirc/BOV to see if that helps alleviate the issue. This car will be my DD for the time being and its rather frustrating to have it happen so often! It makes me cringe releasing the throttle.
Anyone able to chime in? Thanks
Perrin FMIC
DW740cc injectors
TGV deletes
Prodrive ECBS
