Posted on Nasioc, figured I'd share here as well
Event: Dyno
Ambient Temp: 45*
Elevation: ~900
Car: 2015 STi
Tuner: BrenTuning
Dyno Info: Mustang MD150 AWD
Transmission: 6MT
Gear: 3RD
Peak HP at RPM: 400.5 @ ~6300
Peak Torque at RPM: 370 @ ~4700 (earlier in 4th or on street)
Baseline HP/TQ for a stock 2015 STi: 240/240
Target Boost: ~20
Fuel: 93 Oct + Meth for cooling (not for tuning/power)
Engine/Power Modifications:
- Stock engine/Clutch/Trans/Mounts/Suspension 18K miles
- Blouch 3.5XT-R
- KillerB 2 bolt header Swaintech coated
- Grimmspeed thermal coated DP
- Grimmspeed TMIC Thermal coated w/ y-pipe kit
- ETS "Quiet" Catback
- Perrin 3" inlet
- IAG TGV
- ID1000
- Cobb stumble kit
- IAG Street AOS
- Cobb EBCS
- AEM 320 Pump
- AEM Meth in factory washer reservoir for cooling only
Figured I'd post this car up based off of customer feedback -- it has garnered a lot of attention on our FB/IG. Customer contacted looking to maximize the stock engine until he can go rotated/closed deck, this should hold him off for a little while
. This setup is designed around the factory engine to maximize the OEM powerband. Power on the street comes on fast, while obviously it does come on slower than stock, it almost always is making the same TQ (and more) as the VF48. This is on 93 pump with an AEM meth kit (mounted in the front bumper and utilizing the factory washer tank) used for cooling only, not power production. Car made 360WHP on the internal gate it came with, we left it at a very gentle 20PSI for stock engine/clutch longevity. I have basically the same setup on a built engine, stock heads, 93/meth doing 510WHP driven incredibly hard for the past 1.5 years. It really is a great turbo.
Contact:
Email: Sales@brentuning.com
Phone: 508-762-1769
Instagram: @brentuning
Facebook: Facebook.com/brentuning
Chris
Event: Dyno
Ambient Temp: 45*
Elevation: ~900
Car: 2015 STi
Tuner: BrenTuning
Transmission: 6MT
Gear: 3RD
Target Boost: ~20
- Blouch 3.5XT-R
- Perrin 3" inlet
- IAG TGV
- ID1000
- Cobb stumble kit
- IAG Street AOS
- Cobb EBCS
- AEM 320 Pump
Contact:
Phone: 508-762-1769
Chris
