'14 sti 18x9.5 +30 what is needed to fit?
1 reading
7.6K views 9 replies 4 participants last post by  red_z28
#1 ·
I have a set of enkei ts9s in 18x9.5+30 with 245/40 tires. What will I need to do to make these fit properly?
#2 ·
may be wrong, but from what I've read on these forums, our year model can take at most a +45 offset w/o any fender mods.
a popular offset size ive seen is +38 on 9.5's and on a lowered car they had to roll/pull rear fenders. I'm guessing for a +30 you might have to roll/pull both rear and fronts if you're not going to do anything fancy with camber adjustments and stay close to stock specs. Then again running a 245/40/18 on 9.5's the tires might be slightly stretched so you might not have to roll/pull the front.
pretty sure more seasoned members will chime in, but thats my 0.02.
#5 ·
With a +30 I'm guessing yes but then again a little more info would definitely help.
Lowered on what type of suspension?
Do you have any camber bolts?
How about LCA's?
Only thing that really concerns me is running 245/40's on a 9.5. it looks just a tad too stretched imo. If you're gonna be open to rolling fenders anyways it's be better to just go 265/35 if money permits.
#6 ·
Stock suspension, no bolts yet but will have them, no LCAs. Willing to buy whatever to make this combo fit. I already have the tires and the wheels who'll be here shortly. Once these tires are used up I have no problem going to a 265/35.
#8 ·
Rear fender rolling was all that was needed. Had these on the car for about 6 months until the custom wedsports finally arrived. I have the enkei wheels posted up in the forsale section.
