Repair damaged/stripped brembo caliper mounting threads with heli-coils !
97K views 15 replies 14 participants last post by  NewShockerGuy
#1 · (Edited)
The Following is a DIY guide to repair stripped threading on a front brembo brake caliper on the STI.
Subaru utilizes a steel (19mm) bolt to fasten into the aluminum caliper. The dissimilar metals are subject to 'galvanic corrosion' where the aluminum 'bonds' to the steel. So when you go to take these bolts off, often the aluminum threading in the caliper comes out with them, and wala, the threads are gone and you're kinda screwed (ha). But a helicoil thread repair kit can save your arse.
Another part of the problem maybe that these bolts are often incorrectly over-tightened to 114ft.lb. of torque, whereas they only need to be fastened to 80 ft.lb.
-------------- Brief Instructions--------------
(1) Park car, secure and jack up front end
(2) Remove front wheels
(3) Detach brake line from caliper and remove caliper
(4) Use helicoil kit to repair/restore damaged threads.
(5) Re-install.
***I chose to install stainless steel brake lines in the same sitting.
---------------Tools required---------------
(1) Drill press with collet that will accept a 31/64 drill bit.
(2) Helicoil #554412 kit (M12 x 1.5 x 18mm thread repair kit) ***18mm means the length of the inserts once they’re installed. In the package, they’re like 1 cm long uninstalled.
(3) Jack, jack stands, wheel blocks.
(4) Socket wrench.
(5) Sockets (6-point preferred): shallow/regular 19mm, and 12mm.
(6) Permatex red thread locker. This is carried at most regular auto stores. There is a high-temp version available which is good to 450F, but you’ll have to find it or order on the internet.
(7) ***Optional*** Impact wrench - air or electric. I could only get the stripped/seized bolts out with my electric impact. I bought mine at harbor freight for like $40.
(8) Breaker bar
(9) Socket swivel adaptor
(10) Small vise-grip pliers x2 (one for gripping whatever, other for pinching brake line).
(11) Spray bottle with soapy water.
(12) Paper towels/rags.
(13) Irwin quick grip handi-clamps x2 (12 inch).
(14) 1 foot piece of 2x4 lumber.
(15) Blue painter’s tape.
(16) Simple Green/degreaser/cleaner.
(17) Old tooth brush
(18) PB blaster/peneterating oil/cutting oil for tapping
(19) Pieces of cardboard/old box
(20) Wood shims
(21) Safety goggles/eye protection
(22) Needle nose pliers
(23) i almost forgot, the 31/64 drill bit (it doesnt come with the helicoil kit)
--------------- Detailed Instructions ----------------
(1) Park car on level surface, in gear.
(2) Slightly loosen front lug nuts
(3) Block back wheels, jack-up front end of car, apply jack stands to appropriate places. ***Do not apply emergency brake as you will need to detach brake lines from calipers and if the e-brake is engaged it will pressurize the system and possibly cause over-leakage while doing so.
(4) Remove wheels
(5) Detach brake line mounting from strut with 12mm socket.
(6) I Used a small vise-grip plier to pinch the end of the stock brake line so as little fluid as possible would drain-out when the end is detached. I used some cardboard around the brake line, then the vise-grips. Don't pinch it too tight where you might damage the line.
(7) Detach the brake line from the back of the caliper by loosening the 12mm banjo-bolt. Don’t lose the 2 small metal washers. A small amount of brake fluid will drip out. Don't get this on anything - clothes, paint, caliper powder coat. Use a spray bottle filled with soapy water to spray everything down the brake fluids gets on, and then wipe off with paper towels. I then covered the hole in the caliper with some blue painter's tape to prevent further leakage out.
(8) Loosen the two 19mm bolts attaching each brembo caliper to the knuckle. If your bolts are 'frozen-into' the caliper, they will be very difficult to remove. You'll get the same sensation that you're crossthreading them, which you basically are… i.e.- the aluminum that’s stuck to whatever part of the bolts' threading is botching any good aluminum threads as the bolt screws out. I had trouble getting to the top bolt because of the nuts/bolts attaching my coilover to the knuckle were in the way, so I had to put the socket onto the bolt by hand, attach the swivel adaptor, and then the socket wrench/breaker bar/impact. Be careful once the bolts are almost out, the caliper can fall to the ground! If it does, say goodbye to that nice powder coating (chips/flakes off). I had a short bucket turned upside down with a rag on top ready behind the knuckle to be able to set it on it if you need to.
THE MOMENT OF TRUTH Now you’re ready to closely examine the caliper mounting hole threading to see if you’re in the club, or not (hope you're not!). If the bolts came out seemingly normal, and with no damage, consider yourself lucky, they're probably fine, but double check the caliper hole threading anyhow. I would also suggest using a good/new bolt to thread in/out to check. I would imagine if there was only minimal damage to the threads a re-threader or thread chaser could be used to reshape any damaged threads. If yours are OK, you can read no further; if they're crapped-up, continue.
Apply blue tape to the front surface of the caliper for protection. It will be facing down on the drill press sitting on a cardboard squre.
(9) Get your drill press setup. Make sure it’s level, and the bit is plumb. This is extremely important so the hole you’re reaming is not skewed, and so the rest of the repair will work! If the drilling, tapping, and helicoil-ing is not done exactly where it needs to be, it won’t match the mounting holes on the knuckle.
I used the level from a combination framing square to check that the press table was level, and needed to use some wood shims underneath the press feet to make everything perfect. I placed a small cardboard square on the drill press’ table to protect the caliper. I used a piece of 2x4 to help stabilize the caliper. Get the caliper into position for drilling, then clamp-down the caliper. Also use the level to make sure the caliper is level, on the level drill press. Use wood shims above/below the 2x4 around the caliper as needed.
(10) Crank-down/lower the drill bit several times to make sure it is drilling into the hole dead center based on where you have it clamped-down. Lower the bit to the point of where it is barely contacting the caliper and then turn the collet/bit by hand watching the very edges of the bit rotate against the edges of the caliper hole it will be reaming to make sure it is perfect. If it looks good, you're ready to drill the hole. Take your time and advance in/out several times as you work your way all the way through the hole. Wear your safety goggles and blow away the shavings as you pass in/out. The aluminum is soft and the bit should go through no problems.
Picture of the stripped threads pre drilling:
After drilling:
(11) Now you're ready to tap the new hole with the included tap. ***A tap-vise/tool is not included with the helicoil kit. I guess a vise-grip plier could be used to hold it. I used my tap-vise from another tap & die kit I have. ***It is essential that the hole being tapped is as straight/plumb as possible. Take your time and step back and eyeball-it from different angles to make sure it looks straight/plumb. Advance & back-out after every few turns to remove shavings by spraying with a squirt of penetrating oil or blowing/brushing off. Make sure to go all the way down so that the tapered ends of the tap pass through (beyond) the bottom of the hole until the regular (wide) part of the tap is tapping the end of the hole. If you don't advance the normal (wide) part of the tap far enough, there wont be enough adequately formed threads for the heli-coil insert to thread-into (it wont pass through). I used plenty of PB blaster to periodically spray & lubricate the tap periodically.
After tapping:
(12) Clean the cutting oil/PB blaster out of the freshly tapped threads with some simple green and an old tooth brush. Wipe out with a paper towell/rag. Clean/blow-out any residual water/lint. The threads are now nice and clean, and ready for application of the threadlocker. Apply a few drops of threadlocker.
(13) Now you're ready to install the heli-coil. Follow the instructions provided with the kit and diagram. The first one is an anxious moment, but then the rest go very smooth. Insert the helicoil into the large, long, hexagonally shaped what I will call "heli-coil holder" plastic part. Just slide it in, make sure its sitting in the bottom like it should. Then, thread what I will call the black "heli-coil introducer thing" through the "holder" and into the heli-coil, as shown, I used a small vise-grip to hold the end; alternatively, I could have used the tap-vise.
Now Place the heli-coil apparatus ("holder" + "introducer") over the tapped caliper hole. Use one hand to hold the "holder", and the other will turn the "introducer" which will then thread the helicoil into the hole. Hold the "holder" firmly against the caliper and maintain some pressure and slowly start to screw the heli-coil in by turning the "introducer". (The "holder" remains stationary). As the firts few heli-coil threads thread-into the hole it feels tough, kinda like its possibly crossthreading, but that's normal. As the heli-coil starts to engage a few threads it will then seem to start threading-in easier. At that point you only need to loosely hold the "holder".
Keep threading it in until it looks like below (almost all the way in). Turn a few more times until the very end (tpp) of it is 1/4 to 1/2 turn into/below the edge of the tapped threads in the caliper hole. Also turn the caliper over and check the underside of the hole to make sure you havent threaded the insert in too far (through). The bracket/hole is roughly 20mm deep whereas the insert expands to 18mm when inserted, so there should be about 1mm of tapped threading above/below the inserted heli-coil. So it should be right in the middle of the tapped threads with about 1mm of threads left on either side (It's almost all the way threaded-in in the picture below).
***If you sense any significantly abnormal resistance while you're threading the heli-coil in, abandon that heli-coil, and remove it. Stop advancing the "introducer" + heli-coil, and unscrew the "introducer " from the heli-coil. It will screw right out of it and the heli-coil will stay in the hole where you left it. Pull it out with a needle-nose plier. Do this by grabbing the tang. It will un-coil. At that point double-check the tapped threads with your tap. If the tapped hole is ok, it was probably some odd problem with that specific heli-coil you were installing or it wasn't being inserted perfectly right. Start over with a fresh heli-coil. This happened to me on one of mine and the 2nd time it went in fine.
When the heli-coil is in the appropriate place it should look like this:
The "tang" (end/bottom of the coil) will still be attached at the bottom and need to be knocked-off per the instructions. I used the end of a drill bit that fit nicely into the hole.
(14) Test-fit with one of the 19mm bolts, wipe off any excess threadlocker if needed. Remove the bolt and let dry overnight. Then you're done, caliper is ready for re-installation... remember only to torque the bolts to 80 ft.lb. when reinstalling on the knuckle.
Good luck!
This post has been deleted
#5 ·
#4 ·
Thanks for putting up these instructions!
I have just finished installing a helicoil in one of my rear calipers.
I used this helicoil kit:
Helicoil 5546-10 M10x1.5
So I took a different approach then suggested here to square up the caliper for drilling.
After fighting with a few different wooden jigs I gave up and pretty much wrapped the caliper in a few plastic bags and then put it in a small card board box, and then filled the box with "Great Stuff" expanding foam, while holding the caliper square using the drill press.
This pretty much resulted in a caliper embedded mostly rigid foam in a small card board box which was now easy to hold in place so I could drill it.
Great Stuff expanding foam is typically used to seal gaps and cracks in buildings - I have been using it to make molds of things for art projects for a while now. The key things to know about working with expanding foam are:
1 - It is extremely sticky - if you get it on yourself or other things it will stick like crazy - gasoline and stuff like brake cleaner will remove it. (Pro-tip... don't get it in your hair or on your pets!)
2 - It will expand slowly and expand larger then you think - use it sparingly or else you'll find that you have foam overflowing everywhere!
3 - Don't lay it on too thick do 3/4" or single layers of it separated by a few minutes with a spritz of water - this will cause it to cure quicker
4 - If in doubt do a layer at a time until you have filled the cardboard box - wait about 15 minutes between layers.
5 - How much and how quick it expands is very temperature dependent.
6 - If you lay the foam on too thick it won't ever dry, so one layer at a time, with a spritz of water.
** This has the potential to be an extreme mess - so you may want to practice it with an empty box first to get the feel of working with expanding foam. **
**I would only recommend this method if no suitable other method for holding the caliper square can be found!! - the foam is not completely rigid - it has some give - but it will hold the caliper in place - so it is possible for the caliper to become non-square - if too much force is applied while drilling the caliper**
You will need:
- rubber/latex gloves
- brake cleaner / gasoline (Some solvent)
- Great stuff expanding foam in the red can (From Lowes or Home Depot)
- Plastic bags (with no holes!!) large enough to contain the caliper
- Duct tape
- A small cardboard box which is large enough to place the caliper in, it will help if you can make sure it is deep enough the foam won't easily overflow the edges of it.
Here is how I did it:
1. Get some "Great Stuff Expanding Foam" from Home Depot or Lowes (I got the one in the red can for gaps and cracks
2. Find a small cardboard box big enough to hold the caliper, but also fairly deep, so when the foam expands it won't overflow on to the ground.
3. Inspect and tape up the seams on the bottom side of the box - you want to foam to stay in the box and not leak out.
4. Figure out some way to square the caliper up in your drill press - my caliper still had enough threads to thread a tap into it, and then tighten the tap into the chuck on the drill press - pretty much suspending the caliper from the chuck of the drill press.
5. Using a spray bottle filled with water gently mist the inside of the box with water (foam cures more quickly if you use water)
6. Wrap the caliper & drill press in plastic bags (make sure the plastic bags have no leaks) - tape them off so foam will not leak onto the drill press or caliper. In my case I had the plastic bags covering the caliper and up onto the head of the drill press, I taped the plastic bags tightly around the drill press. The goal being that expanding foam will never contact the metal bits on the drill press or caliper directly.
** You should assume anything that the expanding foam touches it will stick too, so it is key that the expanding foam must not make contact with anything that isn't disposable!! - Remember to wear rubber gloves, do this out doors, and have good ventilation*
7. Evenly spray about 3/4" inch or one layer of foam into the bottom of the box - use it sparingly, I did a zig zag pattern of one layer of foam on the bottom of the box - with expanding foam less is more.
8. Using the drill press stand to support the cardboard box, raise it up so the caliper is now sitting in the layer of expanding foam which you have spread on the bottom of the box. I purposefully pushed the caliper so it would contact the bottom of the cardboard box.
9. Spray about two more layers (3/4" thick) of expanding foam around the caliper so that once expanded the foam will hold the caliper in place, spritzing with water between layers. (When I was done the foam had expanded to about 2" above the caliper, but it did not overflow the cardboard box).
10. Depending upon the temperature it will take a few hours for the foam to fully expand, don't leave the foam alone until you are confident it has fully expanded - or else you may come back to a drill press that is embedded in foam.
11. Wait 24 hours
12. Using a razor blade cut away any excess foam which would prevent you from drilling the caliper, in my case I pretty much cut around the cardboard box exposing the top of the caliper.
13. Recenter and check the alignment of caliper and the drill press
14. Slowly and gently drill the new hole for the helicoil - the foam has some give so don't apply too much pressure or else you won't be able to keep it square.
15. Once drilled you can simply yank the caliper out of the expanding foam mold you made of it.
#7 ·
8/17: cleaned up.
#9 ·
I would err on the side of caution, as the OP indicated. If you don't have a vertical drill press readily available, I'd suggest taking these instructions to a decent mechanic shop. I followed the instructions to a "T" and the solution worked. The Heli Coil pack is rather expensive, but much cheaper than paying for an OE replacement calliper.
With the right tools and some patience, this solution is solid. Don't take a short-cut.
#14 ·
I just did this too. Thanks for the great write-up.
I skipped the drilling step after a Subaru tech told me not to bother. In my limited experience, if you're tapping by hand, it will naturally follow the path of least resistance and straighten itself if you are slow and steady. But, that's just me... do so at your own risk...
Also, I was surprised by how easy it was to tap the calipers by hand...
#16 · (Edited)
I'm confused.
The Helicoil kit that is recommended for the front calipers are:
But the Time Cert kit is: M12x1.5
Not so sound like an idiot but what is needed for a 2005 STi front brembo. I had one broke bolt snap in the caliper.
I also don't know the sizes for the rear caliper since a bolt broke in that as well. Would also like to use Time-Sert kit for the rear.
EDIT:
I would prefer to go with the Time-Sert kit now reading on it. Seems way better.
What is the size of the rear brembo caliper bolt? I think I found it but not sure 100%.
M8 x 1.25mm?
This would be the Time-Sert kit for the rear?
Amazon.com: Time-Sert M8x1.25 thread repair kit #1812 by TIME-SERT: Automotive
-Nigel
