2005 Saab 9-2X Aero 128k Miles 5 Speed Part Out
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
Catless Downpipe (Slip on style/No flange for cat back) $75
Intake Manifold $100
Coolant Expansion Tank $35
OEM Pressure Plate $50
Shifter Assembly $50
Axles $75
Transmission Crossmember $50
Rear Crossmember $100
Rear Differential "T" Crossmember $100
Alternator $65
Power Steering Reservoir $25
AC Compressor $100
AC Lines $25+
AC Condenser $50
Washer Fluid Tank $25
Clutch Fork $20
Clutch Fork Rod $20
Wiper Motor & Linkage $40
Charcoal Canister $40
Cruise Control Actuator $40
Rear O2 Sensor 03-07 WRX STi and 04-08 FXT & Baja #22690AA520 $35
Fuel Pump Controller $50
Fuel Pump Hanger $50
OEM Boost Controller #16102AA360 $50
Boost Controller Bracket $10
Timing Covers $15
Suspension, Wheels, Tires & Brakes
OEM Rear Lateral Links $40
Driver Rear Knuckle $75
Front Knuckles $50
Control Arms $50
Trailing Arms $40
Front Calipers $50
Front Rotors $25
Rear Calipers $50
Rear Rotors $25
Front ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
Proportioning Valve $20
Exterior
Doors $150
Driver Mirror $50
Rear Bumper $200
Rear Bumper Beam $50
Hatch $200
Chassis $500
WRX Wagon Roof Rails $75
Gas Lid $20
Wiper Arms $30
Rear Wiper Assembly $30
Trim & Weather Stripping $10+
Passenger Fender Liner $15
Interior
06 WRX Black Front Seats $400
Dash $100
Glovebox $50
Heater Core $75 #72110FE101, 72110FE033 & 72110FE110
Blower Motor $75 #72210FE020
Boston Acoustic SE60 6.5" Component Speakers with Crossovers & Tweeters $75
OEM Front Speakers $20
OEM Rear Speakers $20
Speaker Brackets $10
Cluster Surround $20
Steering Column $75
Window Motor $25
Door Harness $25
Headlight Combo Switch $25
Wiper Combo Switch $25
Rear Defrost Switch $10
Fog Light Switch $10
Cruise On/Off Switch $10
Cruise Control Switch $25 #83151AE000
Hazard Switch $10
Mirror Switch $15
Master Switch $35
Window Switch $10
E-Brake Handle $30
Cup Holder $20
Rear View Mirror $25
Map Light $25
Dome Light $20
Rear Hatch Light $20
Engine & Drivetrain
Axles $75
Alternator $65
AC Compressor $100
AC Lines $25+
AC Condenser $50
Clutch Fork $20
Clutch Fork Rod $20
Timing Covers $15
Front Knuckles $50
Control Arms $50
Trailing Arms $40
Front Calipers $50
Front Rotors $25
Rear Calipers $50
Rear Rotors $25
Brake Booster $50
Exterior
Doors $150
Driver Mirror $50
Rear Bumper $200
Hatch $200
Chassis $500
Gas Lid $20
Wiper Arms $30
Interior
Dash $100
Glovebox $50
Steering Column $75
Window Motor $25
Door Harness $25
Hazard Switch $10
Mirror Switch $15
Master Switch $35
Window Switch $10
E-Brake Handle $30
Cup Holder $20
Map Light $25
Dome Light $20
