1 - 5 of 5 Posts
Do you guys know if the 02-03 wrx sti style strut tower bar (front+ rear) will fit 04 usdm STi? [/u]
curious as to why you dont just go with the 04 sti ones? They're just as expensive and are gaurenteed to fit, some WRX strut bars are designed to go over the WRX stock intercooler and therefore might interfere with the STI IC. So ... you'd probably just be as well off as getting the STI ones. Go to ebay... search sti strut (strut bars will come up) and get the sti replica ones. They work great, look great, and are about ~$100 shipped for both front and rear. Good luck!
Went to E-bay, typed in "sti strut" and many, many "02-03 WRX STi struts" came back. No "04 WRX STi". Any idea where else I can order them?
then they are probably the same thing (if the wrx strut bars came up under STI strut, then the ywill probably work.) I got mine from XOXO motorsports. ALong with some other people on there.
most of the strut bars out there for the WRX
will require you to move/reloate your AC lines
in order to fit them properly....
a few companies such as Whiteline
make an oversized (taller)
strut tower bar which clears your AC lines
and your IC with no harm/risk of harm to either.
good luck in your hunt/research
Jamie
1 - 5 of 5 Posts
