1 - 2 of 2 Posts
I ordered an SBC-ID spec 3 from Dan (Guru - he rocks) and was reading up on the UTEC for the WRX, As I want to be as knowledgable as I can be when I go to hook the STi Utec up and all. Then I see where they have their own ABC fitting to replace the stock middle piece in the hose from the T (between the wastegate actuator and compressor housing) to the boost solenoid. (This is the same fitting you replace in the 3/16" mod I believe). Is the SBC-ID still usable? :(... if not does anyone want to buy it? lol I'd rather have the money back and saving for UTEC then to install it, not be able ot use it, and lose like $200 or so. I understand that their ABC pieces goes AFTER the T and so Im hoping that maybe I can still use it for my BC. Thanks for any help.
Discussion Starter · #2 ·
guru? anyone? I guess I will try turboxs next. I'd just like to have control of the boost seperate and a nice monitor for looks and to display ACTUAL psi and not guess at the factory crap. MPa? *sigh*
1 - 2 of 2 Posts
