1 - 20 of 20 Posts
I'm working on collecting a wishlist of sorts, basically just something I can set my sights at working towards. It'll take some time (Year and a half estimated) but I like having goals for myself. First one was getting the STi and I'm so happy I achieved that one :) Any input is appreciated, I'm not necessarily looking for the *best* but I don't want to get a bad product should I succeed. Also, any suggestions on whats not in here that I'll need (Such as suggested may need a new intake if I get a GT35R) is appreciated too :) I am going to add a coilover to this list just havent decided which. I'm also debating on getting the Defi Gauges to replace the clock or mount on the side.
Pricing found on various sites
Bride Brix II (2) BLACK $2000.00
Sparco Harness Bar $399.00
Sparco 75" Shoulder Harness 2 $170.00
Sparco 6-Point Anti-Sub Belt 2 $64.00
Perrin Intake $289.99
Perrin Radiator Hose Kit $149.99
Perrin Radiator Shroud $59.99
Perrin Blow-Off Valve $249.99
Gruppe-S Perrin GT35R Rotated Kit $2799.00
Invidia G200 $610.00
Perrin Crank Pulley $129.99
K&N Filter $40.00
Turbo Wrap $50.00
HKS Turbo Timer Type 1 (Black with Blue Display) $123.20
Manual Boost Controller $79.99
Walbro 255 lph Fuel Pump $109.95
Perrin Fuel Rail System $349.95
Perrin Oil Catch Can - Black $129.99
Perrin Positive Steering Response System (PSRS) $189.99
27mm Whiteline front sway bar $225.00
26mm IPD rear sway bar w/ mounts $220.00
Perrin Front endlinks $139.99
Perrin Rear endlinks $139.99
Perrin Lateral Links $500.00
Defi Boost Gauge $230.00
Defi Link Control Unit V2 $110.00
Whiteline steering rack bushings $50.00
GT Spec Latter bar $161.00
GT Spec fender braces $229.00
GT Spec front lower tie bar $100.00
GT Spec rear T brace kit $600.00
Front strut brace $180.00
Kartboy Short Shifter & F/R Bushings $205.00
Perrin 850cc injectors $639.99
i would go with an electronic boost controller like the AVCR or the Turbo XS DTEC. from the quick glance i took everything else looks ok.
Discussion Starter · #4 ·
Do they make a turbo wrap for the GT35R?
wishlist huh. Well that definately what that is... looks like to me just around 12k worth of mods. In a year and a half you say, good luck. You must make a good living, or like with the folks saving money on rent, food, etc.....
Dont get me wrong...i love your list and wish you luck on accomplishing it!!
Hah, that is a huge list. My wishlist includes sway bars with end links, a quiet 3 inch TBE (I have an accessport), and a 20g tuned for the stock intercooler. That is about it. My goal is to have a car that looks and sounds stock that will run low 12 second ETs and handle itself well on an autocross.
Discussion Starter · #14 ·
Would it be a good idea to get a new FMIC w/ this?
And to answer :
I'm getting a part time job *JUST* to fund these, working 4 hours a day during the week and 6 hours sat/sun. I'll have the money for the parts in a year, the reason I say year and a half I may adjust my schedule to give myself some more free time, and I'm not sure how much a protune and installation will cost. My fiancee's dad wants to start a shop so that may help me out but I like to keep things in scope :D :tup: Thanks for all the input.
Sweet wish-list. I hope eveything turns out well. You can take off the Perrin Intake since the Perrin GT35R kit comes with a BIG MAF intake. Just saved you $300 :D Im on the 3 year plan and then the project should be over with. GT35R, built motor, yada, yada, etc. Im more about the go rather than the show.
Bigggg list, good luck with it! :D
1 - 20 of 20 Posts
