1 - 7 of 7 Posts
4th subaru
Has anyone considered some sort of a filter inside the intercooler scoop to protect the intercooler from road salt? I'm sure it's do-able, but thought I'd check to see if anyone's already experienced any pitfalls or speedbumps along the way.
Hopefully Grillcraft will come out with a pre-fab scoop grille for the STi. Looks to be a bit sturdier than the homebrew approach.
Size of jdm fog light bulb?
I just did my own this weekend and couldn't be happier. It turned out perfect and looks nice. I like saving the money also.
Um, no ... I meant as something to attach a means of filtration to....
It may be a bit extreme to think of a filter for the intercooler, but I've yet to see anything weather a Minnesota winter very well. It seems like no matter how well you take care of a car, the winters here shred, and corrode, and bury under a layer of salt-encrusted crud....
I'd hate for that to happen to my STi.
will you remove it in the summer? i don't know how true it is... but lots of people like to babble about breaking up the air flow and reducing cooling efficiency for the intercooler.
Oh, absolutely I'd remove it in the summer. Summer is much safer for exposed bits like the intercooler. it's just the winter I'm concerned about, and I don't think there'll be any shortage of cool air for the intercooler in Minnesota in the winter.
I'm starting my own personal "Save the 2.5RS" campaign (only one donor so far - me), so hopefully I'll be able to keep my 2.5RS as a winter car. Barring that, however, I'll need a way to keep my TMIC clean.
'Twas a thought, anyway.
are you talking like some sort of K&N filter custom cut and mounted? or maybe just pick up some really cheap low filtration filter...
Discussion Starter #7
I was thinking the latter. Outside elements would wreak havoc on a K&N, I would think. It's cold enough out that I wouldn't want to have to clean the thing every 5k miles.
I suppose the alternative is to actually just put a cover over the IC, attached to the hood – similar to the factory cover in the older 2.5RS.
1 - 7 of 7 Posts
