1 - 3 of 3 Posts
I have an aftermarket headunit(Eclipse AVN series) that is to be installed in a couple days. Will this aftermarket unit, or any aftermarket headunit for that matter interface with the factory Subaru subwoofer/amplifier in my STI? I have searched around on the forum and couldn't find anything. I'm not big on car audio so the stock sub is adequate for me if it will interface with the aftermarket headunit. If so, is there a specific wiring harness that I need to pick up? Any info would be greatly appreciated. Thanks in advance.
Clark_Kent
Yes it should, since the sub is an option and works fine with the stock HU, you shouldnt have a problem, just match the harnesses up together correctly and you will be good to go
you need a subaru harness, easily obtainable at your nearest best buy or circuit city
1 - 3 of 3 Posts
