1 - 3 of 3 Posts
Whiteline:
WHITELINE IS BACK IN STOCK!!!
Strutbars:
02+ WRX /04+ STi Front - $135 Shipped!!!
02+ WRX /04+ STi Rear - $145 Shipped!!!
02+ WRX /04+ STi Front and Rear Combo - $270 Shipped!!!
Swaybars:
22mm Front - 04+ STi - $125 Shipped!!!
22mm Adjustable Front - 04+ STi - $155 Shipped!!!
24mm Adjustable Front - 04+ STi - $175 Shipped!!!
27 / 29mm Adjustable Front - 04+ STi - $225 Shipped!!!
24mm Adjustable Rear - 04+ STi - $175 Shipped!!!
Endlinks:
Bushing Type 02+ WRX Front /04+ STi Front or Rear - $109 Shipped!!!
Bushing Type 02+ WRX /04+ STi Front and Rear Combo- $210 Shipped!!!
Spherical Type 02+ WRX Front /04+ STi Front or Rear - $109 Shipped!!!
Spherical Type 02+ WRX /04+ STi Front and Rear Combo- $210 Shipped!!!
Anti Lift Kit:
Whiteline Anti Lift Kit for 02+ WRX / 05+ STi - $205 Shipped!!!
These ALKs are available in 3 levels: Race (extra cost), Medium, and Comfort.
Steering Bushings:
02-04 WRX /04 STi ONLY - $30 Shipped!!!
05+ WRX / STi ONLY - $57 Shipped!!!
Whiteline Rear Subframe Bushings for 02+ WRX / 04+ STi - $31 Shipped!!!
More Whiteline products available through our site:
Aerosync Carbon Fiber Strut Tower Bar - 02+ WRX / 04+ STi
$169 shipped for Front
Aerosync is pleased to introduce thr carbon fiber strut tower bar for the 02+ Impreza. This strut tower bar is modeled after the STi Carbon Fiber Strut Bar. Features include an exremely lightweight dry carbon bar and ultra-light aluminum end plates. This is NOT an aluminum bar wrapped in carbon fiber cloth; it is genuine dry carbon. The bar weighs in at an amazing 48 oz. and will clear most large top-mounted intercoolers.
Coilovers!!!
Helix DNA Coilovers - 05+ STi Fitment!
$999 Shipped!!!
- 8/6 kg/mm spring rates.
- Exclusively matched valving
- Independently height adjustable lower bracket
- 16 way dampening adjustable
- Light aluminum Shock Body
- Camber Adjustable, Full Pillowballs in the Front
- Comparable to Tein Flex
- "EDFC" in the works
- Excellent balance between street and track coilver
- Fully rebuildable
- Custom spring rates available for additional cost
Zeal Function XS Coilovers - 05+ STi
$2449 shipped! (only three sets in stock!)
-Pillowball camber plates F
-Pillowball camber plates R
-Inverted Monotube dampers, all 4 corners
-8 kg/mm / 6 kg/mm spring rates
-Independently height adjustable lower bracket
-Top of the line high performance coilover
-6 damping adjustments
Helix Endlinks (Full Pillowball)
Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$99 shipped for STi Rear!!!
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
*CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)[/SIZE]
Discussion Starter · #2 ·
Cusco!
Cusco Type OS Strut Tower Bar - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-OS improve chassis rigidity and reduce this flex. Lightweight aluminum and high rigidity oval sectioned pipe used.
$150 shipped for Front
$150 shipped for Rear
$290 shipped for Both
Cusco Type OS-T Triangle Brace - Rear - 02+ WRX / 04+ STi
*Only includes the triangle brace, not the rear strut tower bar.
$125 shipped
$265 shipped w/ Type OS Rear Bar (as pictured below)
Cusco Type OS Strut Tower Bar and Triangle Brace - Front and Rear Combo - 02+ WRX / 04+ STi
$410 shipped
Cusco Sway Bars - 22mm F / R - 04+ STi
-The addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will promote rotation at the rear of the car, while the front sway bar will promote rotation at the front of the car.
$155 shipped for Rear!!!
$239 shipped for Rear with Helix WRX Rear Endlinks (Full Pillowball) - 02+ WRX
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped!!!
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi
-Rear subframe brace is designed specifically for STi rear diffuser.
-Allows easy installation of 06 STi rear diffuser on 02-05 MYs.
-Stiffens chasis resulting in crisper vehicle dynamics and improved handling.
$249 shipped
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front or Rear
Cusco Pillowball Upper Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi - $789 shipped!!!
STi items:
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi
$639 shipped!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
bump!
1 - 3 of 3 Posts
