1 - 5 of 5 Posts
Changing my plugs and doing a compression test to check out a misfire we looked in the cylinder to check for piston damage and seen this. What am I seeing here? Also my plugs were gapped out to .045.
All I'm seeing is the valve relief cutout in the top of the piston (fingernail looking), which is normal. Is this what you're talkin about?
Other than that, MAYBE some carbon build-up, and depending on your mileage is also normal.
I am looking at the small depression just to the left of that. 60k on the engine, plugs look nasty and gapped wide.
plugs are gapped way to far probably the source of the misfire, should be .028-.032
the piston top image shows a piston top with combustion marks/flame propagation
what were the compression results?
I put new plugs back in at .030, there was so much more pep in the step of it now. The compression checked out at 107/112/110/110.
I couldn't believe how bad those plugs where when I pulled them, heck I can't believe it was running decent with that gap and carbon buildup.
1 - 5 of 5 Posts
