1 - 12 of 12 Posts
Looking at buying some 18x8.5 Bronze Work Emotion CR Wheel. What Is the Widest Tire I Can Fit On A 18x8.5 Wheel With A +43 Offset? i was thinkin 235 or 245. i will also be lowering the car with TEIN S-tech springs. THANKS!
· OT stealth mod
you had to make another thread?
considering your spring choice......i would say 225s or 235s......
Discussion Starter · #4 ·
i am doing a bf goodrich gforce kdw, and tein s springs. i want the widest tire possible. so i will probally go with a 245/35/18 tire, will that clear?
because no one replied for some odd reason.
· I Solve Problems
noone should've replied to this one either!
i don't understand how people don't use the search feature.
we should make a sticky that says the following.
Title: "STICKY: Will this tire fit!? find your answer here"
Body:
If you really have to ask you're not ready to go wider than 245.
and if you're lowerd on crap springs stick with 235s.
kthnxbye.
:lol:
/ranttakingoutaggressiontowardsomeoneunknownb/cihadtowalkcrosscampusintherain.
<haha poor kid, i'm usually nice....sometimes>
EDIT1: ok, to be honest if you want it to fit no worries go with a 235/40 18.
and buy some better springs.
EDIT2: why do you want the widest tire possible? (yes this is a quiz)
EDIT3: you're in naples! do you have the car yet? your prof says otherwise.
EDIT4: <just so people know i'm not trying to "pad" my post count LOLs>
· OT stealth mod
Body:
kthnxbye.
:lol:
:lol: ding. i was hoping you would respond :lol:
<sure.....>
I have an 06 STI w/ same wheels, running 235/40/18 Dunlop FM901s no rubbing whatsoever on S-techs. you can go 245, but would have to slim down to a 35 but depending on tire also. 35 series gets too rough of a ride, 40 series has a lil more meat and drives better for me. but its all preference. good luck!:cool: :tup:
· I Solve Problems
JDM_addict said:
My 04' STi on S-tech springs:
Your answer: 265/35/18
but you're special. :lol:
you wanted to make them fit.
most people just want to buy tire, mount tire, mount wheel to car, drive home. :lol:
· I Solve Problems
I see your logic where 35 is shorter than 40.
but if the overall diameter is the same, and the only difference is section width, wouldn't a 35 and a 40 side wall be the same size?
EDIT: let me refrase that, if the overall diameter is the same and the only difference is section width a 35 profile and a 40 profile are the same size.
now, if you had a 225/40 18 and a 225/35 18. sure the 35 is going to suck.
not if he drops 600 bucks on a set of tires and they rub.
1 - 12 of 12 Posts
