1 - 7 of 7 Posts
For people that bought for invoice!
I just got my SBC-ID and wanted 2 know what an ideal boost setting and gain setting would be. The boost controller is the only thing that I have right now for about another month till I get my turbo back exhaust.
EVO MR?
What do you mean by "ideal"? You need to experiment and find out. I haven't fully checked mine out, but I usually have mine set at 52 and 15. I have peaked at around 15.8 with that. Move it to 55 and 15, and there seems to be a huge difference (peaking around 16.7 and spool up much much quicker). I once had it at 58 and 18 and hit 17.0 (where the limiter is set at) in 4th. Just play around with yours for a while to get used to it.
im not 100% sure about how gain works, but the instructions themselves say dont go over 15 on most stock cars... as for my setttings... I have 52/54/56/58 and 15. Anywhere from 14.5-17 in there in 5-6th. My wastegate is ported so I believe it takes a tad more to get it up to boost (although thats not a problem with the EBC).
It will vary greatly depending on the weather temp., and mods, and what you're comfortable w/ running, boost-wise.
I use all 4 channels (set based on outside temp.) and try to hit 15psi in 4th and max at 15.6-15.9psi in 6th.
Here are my settings:
1-41/9 (0 degrees F)
2-46/11 (25 degrees F)
3-51/13 (50 degrees F)
4-Adjust for Maximum gain
I generally use the 1-3 as a baseline (when the temp is really close to one of the settings-w/in 5 degrees), or as a conservative setting (when I don't have time to play)-I choose the setting immediately below the actual outside temp.
If I do have time, I turn to channel four and adjust my settings, based on the tempurature., as I drive. So, if its 35 degrees I will adjust channel 4 to maybe 48/12ish. And then test.
It hasn't been warm since I installed it; but eventually I will have 0, 40, and 80 degree settings on chan. 1-3. So, I cover more of the temp. spectrum.
I think this is the easiest method to hit about 95% maximization on each drive, w/ only 1 minute (or less) of tuning. If the temp is w/in 5 degrees of one of your presets, select that preset, no changes needed. Otherwise, go to channel 4 and guestimate the setting. Then juice it in 4th gear a couple times, adjusting until you hit your target number (i.e. 15). Simple, fast, effective!
Stikya -
Just curious...why are your settings so low? Do you think the turbo can't handle anything higher? I am trying to peak at 16.3-16.5. Any set of under 50 feels to me like it spools slower than stock.
elucas730 said:
Stikya -
Technically, set doesn't affect how quickly you spool, gain does. Set means how high (psi) you spool. But... I'm sure that's what you meant and that aside...
1) I am a little conservative. A few extra whp (10-20) aren't worth the chance* of detonation and engine deterioration, to me. *Dan, Guru, has mentioned that due to our timing advance, he has experienced pre-ignition/timing knock as low as 16. I don't want to det. even once!
2) I have a cold-air intake, so I get really quick spool up, especially w/ cold weather (it's 25F). I always hit 13+psi, in 1st gear-which is definitely better than stock.
Basically, I want to make sure my engine is in tip-top shape when ECUS come out, so I can safely raise boost to higher levels.
1 - 7 of 7 Posts
